SOLVED SUP Sync is not running Sync failed
Getting below error after syncing with microsoft for the updates. Unchecked all the classifications and products.
Still getting the error, Any help appreciated.
sync: WSUS synchronizing categories
Sync failed: UssInternalError: SoapException: Fault occurred InternalServerError~~at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall). Source: Microsoft.SystemsManagementServer.SoftwareUpdatesManagement.WsusSyncAction.WSyncAction.SyncWSUS
STATMSG: ID=6703 SEV=E LEV=M SOURCE="SMS Server" COMP="SMS_WSUS_SYNC_MANAGER" SYS=DC.SCCMLAB.LOCAL SITE=HYD PID=2960 TID=7116 GMTDATE=Mon Mar 18 16:02:23.141 2019 ISTR0="Microsoft.SystemsManagementServer.SoftwareUpdatesManagement.WsusSyncAction.WSyncAction.SyncWSUS" ISTR1="UssInternalError: SoapException: Fault occurred InternalServerError~~at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=0
Sync failed. Will retry in 60 minutes
My SCCM Version is 1802 and No proxy is configured.
I feel there is an issue with the synchronization of the categories and now the issue is resolved.
I have unchecked all the products and classifications and tried the synchronization.
Its worked and i have checked the products and classifications which I need and synchronized, Now everything is smooth.
But I have an issue with the deployment of the patches.
I have deployed the patches to a device collection(Which contain only one device), But when I check the deployment status its showing as unknown and the client not receiving the updated after forcefully started the client actions.
Can you help me on this?
I have a similar situation, but only if I choose "Windows Server 2019" from the list of products (SUP Component -> Product list). If I turn "Windows Server 2019" product off, synchronization works again.
My SCCM version is 1810.
"Sync failed: UssInternalError: SoapException: Fault occurred "
There are many articles similar to this thread. Maybe this is a temporary microsoft problem.
SWalker
