SOLVED SCCM Update / Site Reset causes LogonUI.exe problems
SCCMGov1978
SCCM Update / Site Reset causes LogonUI.exe problems​
Hi All, Desperately after some help please. I'm updating my SCCM from 2010 to 2203 server 2019 and every time I attempt it (No matter which version i'm going to) It fails on Component Install with this error in CMUpdate.log:
" ERROR: CompileMOFFile: Failed to compile MOF E:\Program Files\Microsoft Configuration Manager\bin\x64\TaskSequenceProvider.mof, error -1]"
After i reboot the server I get the following issue even though it was just a failed update:
Then upon reboot I get LogonUI.exe pop up with the message "The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application." The only way I can get the server working again is to restore to Snapshot.
The main errors I see are the following but i have now done everything i can think of to fix the issue including uninstalling anything on the server thats not MECM related.
Info: loading resource DLL for default categories... CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:28 AM 8668 (0x21DC)
WARNING: Failed to find default package file E:\Program Files\Microsoft Configuration Manager\bin\x64\00000409\CMUpdateInstallationStatus.resx. LastError=2 CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:28 AM 8668 (0x21DC)
Info: Failed to load default resource. CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:28 AM 8668 (0x21DC)
Info: Try Load resource from E:\Program Files\Microsoft Configuration Manager\bin\x64\00000409\CMUpdateInstallationStatus.en-US.resx. CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:28 AM 8668 (0x21DC)
WARNING: Failed to find default package file E:\Program Files\Microsoft Configuration Manager\bin\x64\00000409\CMUpdateInstallationStatus.en-US.resx. LastError=2 CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:28 AM 8668 (0x21DC)
Info: Try Load resource from E:\Program Files\Microsoft Configuration Manager\bin\x64\00000409\CMUpdateInstallationStatus.en.resx. CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:28 AM 8668 (0x21DC)
WARNING: Failed to find default package file E:\Program Files\Microsoft Configuration Manager\bin\x64\00000409\CMUpdateInstallationStatus.en.resx. LastError=2 CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:28 AM 8668 (0x21DC)
ERROR: Failed to convert LCID to name. Error 0x00000000. CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:28 AM 8668 (0x21DC)
WARNING: Failed to find default package file E:\Program Files\Microsoft Configuration Manager\bin\x64\00000409\ManagementInsightRules.resx. LastError=2 CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:28 AM 8668 (0x21DC)
Info: Try Load resource from E:\Program Files\Microsoft Configuration Manager\bin\x64\00000409\ManagementInsightRules.en-US.resx. CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:28 AM 8668 (0x21DC)
WARNING: Failed to find default package file E:\Program Files\Microsoft Configuration Manager\bin\x64\00000409\ManagementInsightRules.en-US.resx. LastError=2 CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:28 AM 8668 (0x21DC)
Info: Try Load resource from E:\Program Files\Microsoft Configuration Manager\bin\x64\00000409\ManagementInsightRules.en.resx. CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:28 AM 8668 (0x21DC)
WARNING: Failed to find default package file E:\Program Files\Microsoft Configuration Manager\bin\x64\00000409\ManagementInsightRules.en.resx. LastError=2 CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:28 AM 8668 (0x21DC)
ERROR: CompileMOFFile: Failed to compile MOF E:\Program Files\Microsoft Configuration Manager\bin\x64\TaskSequenceProvider.mof, error -1 CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:32 AM 8668 (0x21DC)
ERROR: Failed to compile MOF file E:\Program Files\Microsoft Configuration Manager\bin\x64\TaskSequenceProvider.mof. CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:32 AM 8668 (0x21DC)
ERROR: Failed to install/Upgrade SDK Server on CC-SVR-SCCM12.melville.local. CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:32 AM 8668 (0x21DC)
InstallComponents failed CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:32 AM 8668 (0x21DC)
INFO: Site Component Manager installation completed. CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:37 AM 8668 (0x21DC)
INFO: SQL Connection succeeded. Connection: SMS ACCESS, Type: Secure CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:37 AM 8668 (0x21DC)
Turned on activation for service broker queue CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:37 AM 8668 (0x21DC)
Failed to apply update changes 0x80004005 CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:37 AM 8668 (0x21DC)
Error information persisted in the database. CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:37 AM 8668 (0x21DC)
ERROR: Failed to process configuration manager update. CONFIGURATION_MANAGER_UPDATE 15/03/2023 11:17:37 AM 8668 (0x21DC)
We have the same problem. Yesterday we repeat the process of the upgrade withe tehe same result. Crashed installing de sms provider and logonui.exe error in the SQL Server. We need in each situation to revert snapshots in order to have the infrasrtucture again online.
We need help please!
It is not support to restore ConfigMgr like this. It can cause problems, particularly with client and inventory. You should open a support case with ms.
mattjimf
