SOLVED SCCM Installation Client - Offline
  • Thread starter Thread starter egonrusso
  • Replies Replies 4
egonrusso
Guys, I need to install the SCCM client fully offline, but with the "SITE", smsmp and DNSSUFIX already set. I have removed the client directly from the server (SMS_SITE), which contains approximately 610MB of files. However, when I try to run it via command line, it does not load all the information in the Configuration Manager in the control panel.
Algum motivo pelo qual você removeu o instalador do cliente do site principal?
Good afternoon, sorry for the word remover, I didn't remove it, I just copied the client directly from the server and created the application in tasksequence
I am using the command ccmsetup.exe /noservice /UsePKICert SMSSITECODE=ABC smsmp=contoso.com.br DNSSUFIX=contoso.com.br
I need the client installation to be completely offline, so that when I join the domain or connect to the internet, it automatically starts reporting to the system center
mattjimf
