SOLVED SCCM- deploy sw same as run as administrator
  • Thread starter Thread starter berta87
  • Replies Replies 1
  • Views Views 6K
berta87
hi all,
i have to deploy a script setup.exe ( add.in outlook).
if i launch manually the script it'll install but i'll never see the plugin uploaded in outlook, if i launch with the option " run as administrator" the addin 'll be uploaded in outlook and i can use it.
with sccm ho i can deploy the addin with the option "run as administrator" same as right click mouse and "run as administrator".
I hope someone could help me.
thanks
Davide
CM by default deploys sw using the local system account.
if you want to deploy to the user then you need to change the deployment option to deploy as the user instead. This setting varies if it is a app or a program but it is a setting on either the deployment type or the program.
lynnc
