SOLVED SCCM 1802 update stuck downloading state
base
I have a few issues with my SCCM server and I beleive that installing 1802 may address most if not all my issues. Here's what I currently have installed update wise. How do I install 1802? It's been on downloading for a week now. Should I keep waiting?
If you don't have Intune in your environnement, you just ignore those messages.
Any news about the installation of 1802?
I came in the office today and it started getting the blue screen again. Could not get into safe mode. After a few restarts I was able to get into the server. Now the SQL server does not open. Here are the screenshots:
SQL server error
event viewer, The system shutdown randomly last night for no reason.
Several services were stopped, this has been happening often when I have been restarting the server recently.
Looks like you need to focus more on fixing the server side issues first before you jump to fix SCCM issues. I know it's tough but that's how you learn and gain knowledge.
I think you are right. On a side note, 1802 is still downloading. Took a look at the log and noticed that it was showing the same intune warning till the server shutdown last night at 7pm. Once I started it today, the server is now downloading it.
In other news the SCCM server is looking great so far. I think the downloads are coming through without any issues. Praying for no more blue screens.
still no change in update status. I keep seeing the intune subscription line now that is all I mainly see with download installation.
Here is the constant error:
ERROR: Failed to download redist for eab25b02-02dd-4a14-b6d0-ba5bde540d66 with command /RedistUrl http://go.microsoft.com/fwlink/?LinkID=854850 /LnManifestUrl http://go.microsoft.com/fwlink/?LinkID=855609 /RedistVersion 201802 /NoUI "\\RO-WINSVR-02.IDC-S2.LOCAL\EasySetupPayload\eab25b02-02dd-4a14-b6d0-ba5bde540d66\redist" . SMS_DMP_DOWNLOADER 5/23/2018 3:08:00 PM 4900 (0x1324)
Thanks for the tip on the Update Reset Tool. Had similar issues but seems to be working for me now. Currently on the installation phase.
Hi, i used the tip on the UpdateResetTool aswell and the Powershell finished with succes. So the stuck 1802 updated vanished and now i am unable to download it again.
The path under 'C:\Program Files\Microsoft Configuration Manager\EasySetupPayload\ConfigMgr.Update.Manifest.cab mentioned doesnt exist.
Any suggestions? Restart of SMS_EXECUTIVE and SCCM Server didnt change anything.
Thanks, Dennis.
Thanks, Dennis.
So I solved the problem by myself.
FYI, it was a permission problem with the folder EasySetupPayload the user had not enough rights to write into that dircetory and after i changed that everything works fine.
dimasyandr
