SOLVED Failed to connect to machine policy namespace. 0x8004100e
lulu
Hi everyone,
I'm writing to you because I'm loosing my mind and running out of solutions.
My company had SCCM few years ago and decided to have it back.
Architecture:
Running SCCM CB 2101
We have 3 AD forest non-trusted between each other :
  1. Domain MNG
    1. 15 clients
    2. Primary Standalone Website installed 2101
  2. Domain A
    1. 80 clients
    2. DP/MP/SU installed from the primary site
  3. Domain B
    1. 200 clients
For the installation and debugging, I did the following :
- Re-extended the AD schema
- using domain admin account for each domain to allow the primary site connection
- added each domain in AD forest on SCCM
- Install on DP/MP/SUP servers of Domains A and B the client SCCM to make DP working
- Configure the BD groups with subnets and AD site discovered
- All is configured in HTTP
- Auto approval of unknown computers
- allow anonymous client to contact the DPs
- No Windows Firewall enabled on clients / servers
- Checked the network firewall and look like nothing is blocked.
- review the IIS features and looks ok
- No relevant error on the site status
So far I have been able to install the client only on the sccm site servers manually and get them working.
When I try to install the client by push or manually, it install it, return code 0 at the end but show following error in ccmsetup.log : Failed to connect to machine policy namespace. 0x8004100e
On the clients, the software center is not present (weird?) but in the control panel I have access to the CM settings.
I attached the ccmsetup.log (anonymized).
My questions are :
1) Does my architecture is ok ? Or I should install a CAS on MNG and deploy Primary sites on each domain ?
2) Any ideas regarding this issue ?
3) The clients where i'm testing are W10x64 Enterprise LTSC 2019 (1809)
Thanks in advance !
/Lulu
joita
