PENDING WinGet - PS detection method
  • Thread starter Thread starter m0rph
  • Replies Replies 5
  • Views Views 5K
m0rph
The below script works fine in PS ISE (run as LOCAL SYSTEM). But when used as a detection script, I keep seeing this error:
In-line script returned error output: The expression after '&' in a pipeline element produced an object that was not
valid. It must result in a command name, a script block, or a CommandInfo object.
At C:\WINDOWS\CCM\SystemTemp\44632d8b-862d-4dd4-8c7b-b768c8c61543.ps1:1 char:29
+ ... getShow = & (Resolve-Path "C:\Program Files\WindowsApps\Microsoft.Des ...
Script:
$WingetShow = & (Resolve-Path "C:\Program Files\WindowsApps\Microsoft.DesktopAppInstaller_*_x64__8wekyb3d8bbwe\winget.exe") show --id Zoom.Zoom
foreach ($Show in $WingetShow){
if ($Show -like 'Version: *'){
$VersionLine = $Show
$LatestVersion = $VersionLine.trim("Version: ")
$WingetList = (Resolve-Path "C:\Program Files\WindowsApps\Microsoft.DesktopAppInstaller_*_x64__8wekyb3d8bbwe\winget.exe") list --id Zoom.Zoom
foreach ($List in $WingetList){
if ($List -like '*Zoom.Zoom*'){
$VersionLine2 = $List
$VersionLine2 -match "Zoom\.Zoom (?<content>.*) " | Out-Null
$CurrentVersion = $matches['content'].split(' ')[0]
if ($CurrentVersion -eq $LatestVersion){
write-host 'Installed'
In my environment, I have a script that checks the latest versions of a list of winget applications, then creates/updates a number of MECM collections based on that version, updates PSADT based applications and deployment types (including the mentioned detection script), and spreads installations in time over different collections. Below is my latest version with some improvements. It can find the most recent version of winget.exe and allows 2 methods for determining the latest version (winget of fixed). It now also allows to find the latest version in the application name. For some "weird" applications, this is necessary. SSMS for example is version 18.12.1 today, but appears as 15.0.18424.0 in control panel.
try{
$WingetEXEs = (Resolve-Path "C:\Program Files\WindowsApps\Microsoft.DesktopAppInstaller_*_x64__8wekyb3d8bbwe\winget.exe").Path | measure-object -line
$WingetPath = (Resolve-Path "C:\Program Files\WindowsApps\Microsoft.DesktopAppInstaller_*_x64__8wekyb3d8bbwe\winget.exe")[$WingetEXEs.Lines - 1].Path
$LatestVersionSource = 'MECM'
$LatestVersion = $null
$CurrentVersion = $null
catch{}
if ($LatestVersionSource -eq 'Winget'){
try{
$WingetShow = & $WingetPath show --accept-source-agreements --id 7zip.7zip
$VersionLineLatest = $Show
$LatestVersion = $VersionLineLatest.trim("Version: ")
catch{}
if ($LatestVersionSource -eq 'MECM'){
$LatestVersion = '22.01'}
try{
$WingetList = & $WingetPath list --Id 7zip.7zip
if ($List -like '*7zip.7zip*'){
$VersionLineCurrentId = $List
if (!($VersionLineCurrentId)){
$WingetList = & $WingetPath list --Name '7-zip'
if ($List -like '*7-zip*'){
$VersionLineCurrentName = $List
if ($VersionLineCurrentId){
$VersionLineCurrentId -match "7zip\.7zip (?<content>.*) " | Out-Null
if ($VersionLineCurrentName){
$VersionLineCurrentName -match "} (?<content>.*) " | Out-Null
$VersionLineCurrentNameSplit = $VersionLineCurrentName.Split(" ")
$CurrentVersion = $VersionLineCurrentNameSplit[-1]
if (($CurrentVersion -ne $null) -and ($CurrentVersion -ge $LatestVersion)){
catch{}
These are the applications I deploy and update with this method:
7-zip
Anydesk
Belgium e-ID middleware
Belgium e-ID viewer
Citrix Workspace
Dell Command | Update
Google Chrome
Greenshot
Java 8 Update
Local Administrator Password Solution
Microsoft ASP.NET Core 5
Microsoft ASP.NET Core 6
Microsoft .NET Runtime - 5
Microsoft .NET Runtime - 6
Microsoft Edge
Microsoft SQL Server Management Studio
Microsoft Visual C++ 2005 Redistributable
Microsoft Visual C++ 2005 Redistributable (x64)
Microsoft Visual C++ 2008 Redistributable - x86
Microsoft Visual C++ 2008 Redistributable - x64
Microsoft Visual C++ 2010 x86 Redistributable
Microsoft Visual C++ 2010 x64 Redistributable
Microsoft Visual C++ 2012 Redistributable (x86)
Microsoft Visual C++ 2012 Redistributable (x64)
Microsoft Visual C++ 2013 Redistributable (x86)
Microsoft Visual C++ 2013 Redistributable (x64)
Microsoft Visual C++ 2015-2022 Redistributable (x86)
Microsoft Visual C++ 2015-2022 Redistributable (x64)
Microsoft Windows Desktop Runtime - 5
Microsoft Windows Desktop Runtime - 6
Mozilla Firefox
mRemoteNG
Notepad++
Powershell 7
PuTTY
Screenpresso
TreeSize
VLC
Vmware Horizon Client
Webex
Windows Terminal
WinRAR
WinZip
Wireshark
Zoom
Enable this option and check again? This may display if it requires any user acceptance.
Based on the output, you can customize your script in 100% silent mode.
Thank you, the second version of the detection script (here in post #3) is actually working fine.
I do set the deployments to hidden for all applications. Only our pilot group gets second deployment as "available", so installations stay visible in Software Center / Installation status.
lucasavalora
