- Solutions
- 4
GOOD DAY ALL
We have faced many issue while preparing customer reports , Main issue was collections were not getting updated and actual count was not showing in reports . So we came up with PS to update the collection . So we could run the script before taking the reports. Here i am showing Script and how it will work . So that everyone can make the use of it
1.Make one folder under any drive and copy the script and create one notepad Collections_list.txt - mention the collection names ,
2. I have mentioned some areas in the script to modify and not to modify .
#Script created by Gokul
# Press 'F5' to run this script. Running this script will load the ConfigurationManager
# module for Windows PowerShell and will connect to the site.
# This script was auto-generated at '3/17/2020 1:41:05 PM'.
# Uncomment the line below if running in an environment where script signing is
# required.
#Set-ExecutionPolicy -ExecutionPolicy Bypass -Scope Process
# Site configuration
$SiteCode = "S01" # Mention Site code
$ProviderMachineName = "XYZ.com" # Mention SMS Provider machine name
# Customizations
$initParams = @{}
#$initParams.Add("Verbose", $true) # Uncomment this line to enable verbose logging
#$initParams.Add("ErrorAction", "Stop") # Uncomment this line to stop the script on any errors
# Do not change anything below this line
# Import the ConfigurationManager.psd1 module
if((Get-Module ConfigurationManager) -eq $null) {
Import-Module "$($ENV:SMS_ADMIN_UI_PATH)\..\ConfigurationManager.psd1" @initParams
# Connect to the site's drive if it is not already present
if((Get-PSDrive -Name $SiteCode -PSProvider CMSite -ErrorAction SilentlyContinue) -eq $null) {
New-PSDrive -Name $SiteCode -PSProvider CMSite -Root $ProviderMachineName @initParams
# Set the current location to be the site code.
Set-Location "$($SiteCode):\" @initParams
$ScriptDir = Split-Path $Script:MyInvocation.Mycommand.path
$date = Get-Date -Format "dd-MM-yyyy hh:mm:ss"
$log = "$ScriptDir\Status.log"
$ImportColl = Get-Content $ScriptDir\"Collections_list.txt"
$DeviceCollections = Get-CMDeviceCollection -Name $ImportColl | Select Name , CollectionID
"--------------------- Script executed on $date (dd-MM-yyyy hh:mm:ss) ---------------------" + "`r`n" | Out-File $log -append
foreach($Devicecollection in $DeviceCollections)
try
"$date [Info]`t Getting Collection Name '$($Devicecollection.Name)'" |Out-File -Append $log
Invoke-WmiMethod ` -path "root\sms\site_P01:SMS_Collection.CollectionID='$($Devicecollection.CollectionID)'" ` -Name RequestRefresh -ComputerName $ProviderMachineName | Out-Null
"$date [Info]`t Updated the Collection Membership on Collection '$($Devicecollection.Name)'" | Out-File -Append $log
catch
"$date [ERROR]`t Unable to update membership on collecion '$($Devicecollection.Name)" | Out-File -Append $log
"--------------------- Script execution Completed on $date (dd-MM-yyyy hh:mm:ss) ---------------------" + "`r`n" | Out-File $log -append
OUTPUT
# required.
# Customizations
$initParams = @{}
try
catch
OUTPUT
