Dear Garth, Please find the client error logs (i have removed the DP,MP name as --- )
Client
Client is not allowed to use or doesn't have PKI cert while talking to HTTPS server. ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
[CCMHTTP] ERROR: URL=https://--------/ccm_system/request, Port=0, Options=480, Code=0, Text=CCM_E_NO_CLIENT_PKI_CERT ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
[CCMHTTP] ERROR INFO: StatusCode=200 StatusText= ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Failed (0x87d00454) to send location request to '--------'. StatusCode 200, StatusText '' ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Failed to send location message to 'HTTPS://-------'. Status text '' ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
GetDPLocations failed with error 0x87d00454 ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Failed to get DP locations as the expected version from MP 'HTTPS://------'. Error 0x87d00454 ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Failed to find DP locations from MP 'HTTPS://------' with error 0x87d00454, status code 200. Check next MP. ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Only one MP HTTPS://------ is specified. Use it. ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Have already tried all MPs. Couldn't find DP locations. ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Downloading 'HTTPS://------/CCM_Client/ccmsetup.cab' to 'C:\Windows\ccmsetup\\ccmsetup.cab' ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
IsSslClientAuthEnabled - Determining provisioning mode state failed with 80070002. Defaulting to state of 480. ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
MapNLMCostDataToCCMCost() returning Cost 0x1 ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Failed to connect to machine policy namespace. 0x8004100e ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Client is on internet ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Client is set to use webproxy if available. ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
[CCMHTTP] ERROR: URL=HTTPS://------/CCM_Client/ccmsetup.cab, Port=0, Options=480, Code=0, Text=CCM_E_NO_CLIENT_PKI_CERT ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
[CCMHTTP] ERROR INFO: StatusCode=<unknown> StatusText= ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
DownloadFileByWinHTTP failed with a non-recoverable failure, 0x87d00454 ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
DownloadFileByWinHTTP failed with error 0x87d00454 ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Sending state '308'... ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Updating MDM_ConfigSetting.ClientDeploymentErrorCode with value 2278556756 ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
OS is not Win10RS3+, ENDOK. ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Failed to get client version for sending state messages. Error 0x8004100e ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
[] Params to send '5.0.8968.1014 Deployment Error 0x87d00454. Url
HTTPS://----- ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
A Fallback Status Point has not been specified and no client was installed. Message with STATEID='308' will not be sent. ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Failed to send status 308. Error (87D00215) ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Deleting Comanagement reg keys... ccmsetup 4/27/2021 11:29:17 AM 1688 (0x0698)
Failed to connect to policy namespace. Error 0x8004100e ccmsetup 4/27/2021 11:29:17 AM 7612 (0x1DBC)
Failed to revoke client upgrade local policy. Error 0x8004100e ccmsetup 4/27/2021 11:29:17 AM 7612 (0x1DBC)
Sending state '301'... ccmsetup 4/27/2021 11:29:17 AM 7612 (0x1DBC)
Updating MDM_ConfigSetting.ClientDeploymentErrorCode with value 2278556756 ccmsetup 4/27/2021 11:29:17 AM 7612 (0x1DBC)
OS is not Win10RS3+, ENDOK. ccmsetup 4/27/2021 11:29:17 AM 7612 (0x1DBC)
'Configuration Manager Client Retry Task' is scheduled to run at 04/27/2021 04:29:17 PM (local) 04/27/2021 01:29:17 PM (UTC) time with arguments ' /ignoreskipupgrade /config:MobileClient.tcf /RetryWinTask:1'. ccmsetup 4/27/2021 11:29:17 AM 7612 (0x1DBC)
Folder 'Microsoft\Microsoft\Configuration Manager' not found. Task does not exist. ccmsetup 4/27/2021 11:29:17 AM 7612 (0x1DBC)
Successfully created task 'Configuration Manager Client Retry Task' ccmsetup 4/27/2021 11:29:17 AM 7612 (0x1DBC)
CcmSetup failed with error code 0x87d00454
MECM Server 2002
CCR count in queue "Retry" is 2. SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:12 AM 5840 (0x16D0)
Sleeping for 145 seconds... SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:12 AM 5840 (0x16D0)
---> NetUseAdd failed: 53: dwParamError = 0 SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:22 AM 13612 (0x352C)
---> NTLM fallback is enabled SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:22 AM 13612 (0x352C)
---> WNetAddConnection2 failed (LOGON32_LOGON_NEW_CREDENTIALS) using account ----\adminsupport (00000035) SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:22 AM 13612 (0x352C)
---> The device ------ does not exist on the network. Giving up SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:22 AM 13612 (0x352C)
---> Trying the 'best-shot' account which worked for previous CCRs (index = 0x0) SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:22 AM 13612 (0x352C)
---> Attempting to connect to administrative share '\\-----PC\admin$' using account '----\adminsupport' SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:22 AM 13612 (0x352C)
---> SspiEncodeStringsAsAuthIdentity succeeded! SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:22 AM 13612 (0x352C)
---> SspiExcludePackage succeeded! SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:22 AM 13612 (0x352C)
---> SspiMarshalAuthIdentity succeeded! SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:22 AM 13612 (0x352C)
---> NetUseAdd failed: 53: dwParamError = 0 SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:43 AM 13612 (0x352C)
--> NTLM fallback is enabled SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:43 AM 13612 (0x352C)
---> WNetAddConnection2 failed (LOGON32_LOGON_NEW_CREDENTIALS) using account ----\adminsupport (00000035) SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:43 AM 13612 (0x352C)
---> The device MOFAMAC-PC does not exist on the network. Giving up SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:43 AM 13612 (0x352C)
---> ERROR: Unable to access target machine for request: "2097152422", machine name: "-----PC", access denied or invalid network path. SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:43 AM 13612 (0x352C)
Execute query exec [sp_CP_SetLastErrorCode] 2097152422, 53 SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:43 AM 13612 (0x352C)
Stored request "2097152422", machine name "-----PC", in queue "Retry". SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:43 AM 13612 (0x352C)
Execute query exec [sp_CP_SetPushRequestMachineStatus] 2097152422, 2 SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:43 AM 13612 (0x352C)
Execute query exec [sp_CP_SetLatest] 2097152422, N'04/27/2021 08:59:43', 49 SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:43 AM 13612 (0x352C)
<======End request: "2097152422", machine name: "----PC". SMS_CLIENT_CONFIG_MANAGER 4/27/2021 11:59:43 AM 13612 (0x352C)
The Site Control File has not changed since the last parameter update. SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
Updating Site Parameters SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
MP Ports: 80 SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
IISPreferedPort: 80 SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
MP SSL Ports: 443 SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
IISSSLPreferedPort: 443 SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
Default MP: -------- SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
Default MP Type: 1 SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
Default MP: [None] SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
Certificate Selection Criteria: SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
Certificate Store: SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
SSL State: 480 SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
PKI Cert Options: 0x1 SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
Select First Certificate: 1 SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
Certificate Issuers: SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
Checking configuration information for server: ---------. SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
No Fallback Status Point installed on the Site SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
Install on DC: False SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
Option for installing using IP address: 0 SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
Sleeping for 1200 seconds... SMS_CLIENT_CONFIG_MANAGER 4/27/2021 12:01:37 PM 5840 (0x16D0)
