PENDING task sequence variable to detect language installed
ayadav1622
I am looking for is in windows 10 In-place upgrade task sequence, a task sequence variable to be set that should check the language installed in current OS and if the language is not English, the task sequence should stop and do not continue further.
So far I am trying to understand, how does TS variable helps in identifying the OS Language in the current OS and based on the condition set It should proceed accordingly.
I have created an windows 10 in-place upgrade task sequence and used register setting and WMI query, both of them
Didn’t worked and task sequence proceed, even if the current OS is not English.
897890
897892
897893
897894
Invincy
