I took the jump to make the SCCM implementation SSL. Things aren't going so well. I followed the guide posted on this site (thank you by the way). It looks like there are connection errors to the management point now from clients. Two client log entries:
From CcmMessaging
Successfully queued event on HTTP/HTTPS failure for server 'XXX'.
Post to https://XXX/ccm_system_windowsauth/request failed with 0x87d00231.
From CcmNotificationAgent
Error: Server certificate retrieved in TLS is not an exact match of the current MP encryption certificate.
Error: 0x80090322 authenticating server credentials!
Failed to signin bgb client with error = 80090322.
Fallback to HTTP connection.
[CCMHTTP] ERROR: URL=http://1982-X-MP-1-P01.xactware.com/bgb/handler.ashx?RequestType=LogIn, Port=80, Options=224, Code=0, Text=CCM_E_BAD_HTTP_STATUS_CODE (EDIT: MANAGEMENT POINT IS ACCEPTING HTTPS ONLY)
Has anyone ever seen this before?
From CcmMessaging
