PENDING SQL Server Poly Database Engine and Data Management "start Pending or stuck on startup."
  • Thread starter Thread starter ER_singh
  • Replies Replies 1
  • Views Views 481
ER_singh
I hope you are doing well!
Please help me to find the solution of SQL Server Poly Database Engine and Data Management "start Pending or stuck on startup."
I have also checked the TCP/IP is enabled, But it does not start, showing start pending and I also checked the logon service one time on local user and another time on domain user; it does not work Please suggest the solution to this.
Snippet are attached
  • Sql poly basebase server data movemnet and poly base Engine was not started logon user set.png
  • Sql poly basebase server data movemnet and poly base Engine was not started.png
I am us
I am using MS server 2016 with SQL 2016 server and SCCM configuration MGR 2403
mjmagyar
