SOLVED SQL Reporting Issue
  • Thread starter Thread starter Nav4339
  • Views Views 541
Nav4339
I am using the query below to extract some details for devices in my environment. My issue is that I have a number of devices that x86 OS installed on a x64 Machine. My query returns the result correctly for the OS showing it as x86 OS. However for the machine/processor, it display it as x86 based PC when it is in fact a x64 processor. Is there any way to get around this and getting the reporting issue resolved. The device has been deleted from SCCM, client re-installed, all policies re-run. After 1 week, the results are still the same.
SELECT DISTINCT
CPU.SystemName0 AS [Computer Name],
CS.Manufacturer0 AS [Make],
CS.Model0 AS [Type],
OS.Caption0 AS [Operating System],
OS.BuildNumber0 AS [OS Build Number],
OS.Version0 AS [OS Version],
CS.SystemType0 AS [System Type],
OS.OSArchitecture0 AS [OS Architecture],
CPU.Name0 AS [CPU Model],
COUNT(CPU.ResourceID) AS [Number of CPUs],
CPU.NumberOfCores0 AS [Number of Cores per CPU],
CPU.NumberOfLogicalProcessors0 AS [Logical CPU Count]
FROM
[dbo].[v_GS_PROCESSOR] CPU
LEFT OUTER JOIN dbo.v_GS_COMPUTER_SYSTEM CS ON CS.ResourceID = CPU.ResourceID
LEFT OUTER JOIN dbo.v_GS_Operating_System OS ON CS.ResourceID = OS.ResourceID
WHERE
OS.Caption0 NOT LIKE '%server%'
GROUP BY
CS.Manufacturer0, OS.BuildNumber0, OS.Version0,
CS.Model0, OS.Caption0, OS.OSArchitecture0,
CS.SystemType0, CPU.SystemName0, CPU.Name0,
CPU.NumberOfCores0, CPU.NumberOfLogicalProcessors0
ORDER BY
[Computer Name] ASC;
Result from Query
Confirmation from physical device
Your query does not show the cpu type. It shows the system type. Look within resource explorer for the correct column to use.
