PENDING Some problem with client updates
  • Thread starter Thread starter Degtyarev_da
  • Views Views 7K
  • Tags Tags
    sup
D
Degtyarev_da
Guest
Good day.
There is an incomprehensible problem, the second week not any progress.
The situation is this: It took migrate SCCM 2012 R2 SP1 CU2 2012 server platform. The name and code of the site preserved. What was done. But since 2012 server running WSUS is only 4, the SUP role, I had to redo it.
Procedure:
1. Raised without configuring WSUS
2. Turn on the role of SUP.
3. synchronized, performed the task of auto update deployment.
On the SCCM server updates are synchronized, the desired pumped deployed on the collection status on distribution points - OK.
We turn to the problem itself. On the SMS client updates after the scanning is not available.
In UpdateStore.log - example:
Querying update status of the 64 updates. UpdatesStore
11/27/2015 10:18:23 2696 (0x0A88)
Queried Update (00584797-4409-4bfe-b89e-53acb5b79618): Status = Installed, Title = Update for Windows Server 2012 R2 (KB3078676), BulletinID =, QNumbers = 3078676, LocaleID =, ProductID = cd5ffd1e-e932-4e3a-bf74- 18bf0b1bbd83, UpdateClassification = cd5ffd1e-e932-4e3a-bf74-18bf0b1bbd83, ExcludeForStateReporting = FALSE. UpdatesStore
Queried Update (04f04253-f803-43b8-8b37-6841c614dd9f): Status = Installed, Title = Security Update for Windows Server 2012 R2 (KB3084135), BulletinID = MS15-102, QNumbers = 3084135, LocaleID =, ProductID = 0fa1201d-4330 -4fa8-8ae9-b877473b6441, UpdateClassification = 0fa1201d-4330-4fa8-8ae9-b877473b6441, ExcludeForStateReporting = FALSE.
UpdatesStore 27.11.2015 10:18:23
2696 (0x0A88)
Queried Update (096b9d81-332f-4748-a023-7d37a5ea7ecf): Status = Installed, Title = Update for Windows Server 2012 R2 (KB3101183), BulletinID =, QNumbers = 3101183, LocaleID =, ProductID = cd5ffd1e-e932-4e3a-bf74- 18bf0b1bbd83, UpdateClassification = cd5ffd1e-e932-4e3a-bf74-18bf0b1bbd83, ExcludeForStateReporting = FALSE. UpdatesStore
Queried Update (13412e0c-7eec-4c31-b03b-876c5fa4a54a): Status = Installed, Title = Security Update for Microsoft .NET Framework 3.5.1 in Windows 8.1 and Windows Server 2012 R2 for x64-based Systems (KB3074232), BulletinID = MS15-101, QNumbers = 3074232, LocaleID =, ProductID = 0fa1201d-4330-4fa8-8ae9-b877473b6441, UpdateClassification = 0fa1201d-4330-4fa8-8ae9-b877473b6441, ExcludeForStateReporting = FALSE.
2696 (0x0A88)
Queried Update (150d47ae-3196-4afc-a37e-95d7a2228f15): Status = Installed, Title = Update for Windows Server 2012 R2 (KB3096433), BulletinID =, QNumbers = 3096433, LocaleID =, ProductID = cd5ffd1e-e932-4e3a-bf74- 18bf0b1bbd83, UpdateClassification = cd5ffd1e-e932-4e3a-bf74-18bf0b1bbd83, ExcludeForStateReporting = FALSE. UpdatesStore
Queried Update (15453dab-ae77-42e0-b752-8c7cc91f280c): Status = Installed, Title = Security Update for Windows Server 2012 R2 (KB3083992), BulletinID =, QNumbers = 3083992, LocaleID =, ProductID = 0fa1201d-4330-4fa8- 8ae9-b877473b6441, UpdateClassification = 0fa1201d-4330-4fa8-8ae9-b877473b6441, ExcludeForStateReporting = FALSE.
2696 (0x0A88)
Queried Update (16306add-e04d-4b8d-bf0b-4d14f62ef250): Status = Installed, Title = Security Update for Windows Server 2012 R2 (KB3088195), BulletinID = MS15-111, QNumbers = 3088195, LocaleID =, ProductID = 0fa1201d-4330 -4fa8-8ae9-b877473b6441, UpdateClassification = 0fa1201d-4330-4fa8-8ae9-b877473b6441, ExcludeForStateReporting = FALSE.
2696 (0x0A88)
Queried Update (1e495e58-8a3b-404a-9502-cf6dbd7e27a5): Status = Installed, Title = Security Update for Windows Server 2012 R2 (KB3080446), BulletinID = MS15-109, QNumbers = 3080446, LocaleID =, ProductID = 0fa1201d-4330 -4fa8-8ae9-b877473b6441, UpdateClassification = 0fa1201d-4330-4fa8-8ae9-b877473b6441, ExcludeForStateReporting = FALSE.
2696 (0x0A88)
Queried Update (1eed8026-af28-49fd-9082-8b6946d6a115): Status = Missing, Title = Security Update for Windows Server 2012 R2 (KB3101246), BulletinID = MS15-122, QNumbers = 3101246, LocaleID =, ProductID = 0fa1201d-4330 -4fa8-8ae9-b877473b6441, UpdateClassification = 0fa1201d-4330-4fa8-8ae9-b877473b6441, ExcludeForStateReporting = FALSE.
2696 (0x0A88)
Those. you can see that of the 64 deployed some updates needed to install.
In UpdatesDeployment.log
Total Updates = 64 UpdatesDeploymentAgent
11/27/2015 11:24:59 5968 (0x1750)
EnumerateUpdates for action (UpdateActionInstall) - Total actionable updates = 13
UpdatesDeploymentAgent 27.11.2015 11:24:59
5968 (0x1750)
CUpdatesJobManager :: AnyActiveInstallJobs - Returning false
5968 (0x1750)
Enumerate targeted updates for action = UpdateActionInstall
UpdatesDeploymentAgent 27.11.2015 11:36:32
4168 (0x1048)
A UpdatesHandler.log
Initiating updates scan for checking applicability.
UpdatesHandler 27.11.2015 10:18:10
2696 (0x0A88)
Successfully initiated scan. UpdatesHandler
11/27/2015 10:18:10 2696 (0x0A88)
Updates scan completion received, result = 0x0. UpdatesHandler 27.11.2015 10:18:16
6020 (0x1784)
Updates scan completion received, result = 0x0. UpdatesHandler 27.11.2015 10:18:23
2696 (0x0A88)
Method (Discover) called from SDM. UpdatesHandler
11/27/2015 10:18:23 6020 (0x1784)
Starting job with id = {5BCC9F20-2ADB-483F-A0FB-E1DE5852EAFF}
6020 (0x1784)
Initiating Scan. Forced = (0) UpdatesHandler
Successfully initiated scan for job ({5BCC9F20-2ADB-483F-A0FB-E1DE5852EAFF}).
6020 (0x1784)
Scan completion received for job ({5BCC9F20-2ADB-483F-A0FB-E1DE5852EAFF}).
UpdatesHandler 27.11.2015 10:18:24
2696 (0x0A88)
Evaluating status of the updates for the job ({5BCC9F20-2ADB-483F-A0FB-E1DE5852EAFF}).
2696 (0x0A88)
Successfully sent job ({5BCC9F20-2ADB-483F-A0FB-E1DE5852EAFF}) success completion to the SdmAgent
6880 (0x1AE0)
CompleteJob received from SDM. UpdatesHandler
11/27/2015 10:18:24 2696 (0x0A88)
Complete - Job ({5BCC9F20-2ADB-483F-A0FB-E1DE5852EAFF}) Cleanup.
2696 (0x0A88)
CompleteJob - Job ({5BCC9F20-2ADB-483F-A0FB-E1DE5852EAFF}) removed from job manager list.
2696 (0x0A88)
CUpdatesAgent :: FinalConstruct entered UpdatesHandler
11/27/2015 11:28:53 6196 (0x1834)
Where digging is not clear, as it has updates are deployed, are available but are not siphoned off to customers.
I tried to throw the car registered in the database via the WSUS command wuauclt.exe / resetauthorization / detectnow, but did not help)
okay do you mean to say that after migration of SCCM and re-installing the WSUS and post synchronization, the updates to the client computers are not being delivered ?.
HuwjOnes
