NEW Software Updates not downloading (Air gapped system)
  • Thread starter Thread starter rob287
  • Replies Replies 4
rob287
Active Member
I have my WSUS set up along with PKI and using port 8531/SSL.
I manually export from a internet standalone WSUS server, put onto a External HD and plug into my air gapped system and do the wsusutil import command. Then syc and the updates show up. Happy days :-)
When I do a sync on SCCM it also shows up :)
Problem
When I go to download them and deploy them to a collection (I have win 10 20H2 and server 19), I get failures saying cannot find path ID 16777715 and doesn't download.....but some do download? probably about 50% of updates actually succeed. Its the same path so how are some failing saying cannot find?
Is there any guides for specifically NON Internet facing systems.
im guessing after looking into this. All my servers are showing up as failed client check. So ill have to look into why which eval log doesnt really tell me anything ...
I manually export from a internet standalone WSUS server, put onto a External HD and plug into my air gapped system and do the wsusutil import command. Then syc and the updates show up. Happy days :)
Problem
Hello @rob287
Review the log WUAHandler, UpdatesHandler, UpdateDeployments in C:\Windows\CCM\Logs with CMTRACE in the target client computer. You'll see the error code in this logs.
Twc
