sameermpm
Hi All,
Greetings.
I have one SCCM 2012 R2 server which holds SQL also. This SQL is configured to give database and reporting services to SCCM now. I am planning to install a SCOM server 2012 R2 also. Can I share the same SQL server for SCOM reporting also? I found some forums saying that if use the same SQL server for both SCCM and SCOM, SCOM will screw up the SCCM reporting. Any idea about this issue? If anybody knows about some procedure to follow to share same sql for both sccm and scom reporting, kindly share.
Regards.
Greetings.
Regards.
