SOLVED SCCM SQL Custom Query
select computer_system_data.name00, computer_system_data.username00, SoftwareFile.filename, SoftwareFile.FileVersion, softwarefilepath.filepath
FROM computer_system_data, SoftwareFile, softwareinventory, workstationstatus_data, softwarefilepath
WHERE computer_system_data.machineId = softwareinventory.clientid
and softwareinventory.fileid = softwarefile.fileid
and softwareinventory.filepathid = softwarefilepath.filepathid
and SoftwareFile.filename = 'SoD.exe'
It is not supported to query the tables directly, always use the SQL view. Also ensure that you do you joins correctly.
SQL:
select
    RV.Netbios_Name0,
    RV.User_Name0,
    SF.filename,
    SF.FileVersion,
    SF.FilePath
FROM
    dbo.v_R_System_Valid RV
    inner join dbo.v_GS_SoftwareFile SF on RV.ResourceID = SF.ResourceID
WHERE
    SF.FileName = 'SoD.exe'
