SOLVED SCCM SMS_STATE_SYSTEM CRITICAL ERROR
  • Thread starter Thread starter Jahandar
  • Replies Replies 16
  • Views Views 13K
Jahandar
Hi.We have a critical error in SCCM 1902 Current Branch.Help please.
Microsoft SQL Server reported SQL message 245, severity 16: [22018][245][Microsoft][SQL Server Native Client 11.0][SQL Server]Conversion failed when converting the nvarchar value '^6\' to data type smallint. : spLifecycleRefreshAndSummarize
sccm error.PNGPlease refer to your Configuration Manager documentation, SQL Server documentation, or the Microsoft Knowledge Base for further troubleshooting information.
Hi Guys
Can anyone help, I am getting sync issues but just cant seem to solve the problem.
If anyone has came across this before and managed to resolve please can you share what you did to fix it?
TIA
CL
What does the actual error message say? What troubleshooting have you done?
Hi Garth
Thank you so much for coming back to me. I have been trying to fix this issue for 2weeks now. I am new to SCCM and not sure which steps I need to troubleshoot in this issue. here are some logs if you are able to help or may know what the cause or fix is.
Thanks for helping
Since you have a CAS and therefore over 150k devices, you should open a support call directly with Microsoft. It is a rarity for people to have over 150k of devices.
Because you have a CAS. Only company with 150k device need a CAS.
Oh lol, it was build and like this before I came here hahaah. I managed to get it up and running and synced not Garth.
I am having 1 more issue but cant seem to find a resolution. Have you seen this before trying to delete or edit a package?
TIA
CL
TIA
CL
How is this related to the upgrading of your site? Do you care about this application? Does the Object exist? Can you access it?
No I am trying to delete it, the object is there as I can deploy the application and install it through the software center. it just wont let me edit or delete it.
Regards
CL
dimasyandr
