Yes I check Boundry, everything is Okay and I check client logs there are no problem with boundy, also yes i check guides no problemWhy type of Boundaries are you using? When reviewing the logs, did you check to see if they computer falls within boundaries? Have you looked for duplcate guids?
Why type of Boundaries are you using? Have you looked for duplicate guids?Yes I check Boundry, everything is Okay and I check client logs there are no problem with boundy, also yes i check guides no problem
