tiduseQ
I have overcome many obstacles in creating proper SCCM environment and came upon yet another one. My distribution point that has been up and running until few days ago has stopped working. The
Symptoms:
Uploading package to DP, checking status of content: "detail will be available after the server finishes processing the messages"
I then go ahead, google a little and check my Component Status. Apparently it has been throwing errors for over a month (screen1).
Then I check dmpdownloader.log and I see same error over and over again and something that looks like SCCM update in between all the errors. Log attached.
Does anyone have any idea why the DP is not working and what are the errors listed in dmpdownloader for? The DP has been working correctly (at least returning success content upload status) at least in February.
EDIT: To clarify what else I have been doing. I have created small packages and uploaded them to DP, it worked well. Then I created sample update package with 1 update and it also seems like it has been uploaded successfully. It is only now that I see that something is quite not right.
Symptoms:
