PENDING SCCM - Custom Report Help
ktntech
Would anyone be able to advise how I could create a custom report in SCCM to pull the following information
Machine Name
Make
Model
O/S & Version (21H2)
I'm new to trying to create custom reports so any help would be greatly appreciate.
Thank you in advance for your time and help
Kurt
I have something that can help you, here's the SQL script:
SELECT distinct
CS.name0 as "Computer Name",
CS.domain0 as "Domain",
CS.UserName0 as "User",
BIOS.SerialNumber0 as "Bios serial",
SE.SerialNumber0 as "Service Tag",
CS.Manufacturer0 as "Manufacturer",
CS.Model0 as "model",
OS.Caption0 as "OS",
RAA.SMS_Assigned_Sites0 as "Site",
RAM.TotalPhysicalMemory0 as "Total Memory",
SUM(ISNULL(LDisk.Size0,'0')) as "Hardrive Size",
SUM(ISNULL(LDisk.FreeSpace0,'0')) AS "Free Space",
CPU.Name0 as "CPU Model"
FROM
v_GS_COMPUTER_SYSTEM CS right join v_GS_PC_BIOS BIOS on BIOS.ResourceID = CS.ResourceID
right join v_GS_SYSTEM SYS on SYS.ResourceID = CS.ResourceID
right join v_GS_OPERATING_SYSTEM OS on OS.ResourceID = CS.ResourceID
right join v_RA_System_SMSAssignedSites RAA on RAA.ResourceID = CS.ResourceID
right join V_GS_X86_PC_MEMORY RAM on RAM.ResourceID = CS.ResourceID
right join v_GS_Logical_Disk LDisk on LDisk.ResourceID = CS.ResourceID
right join v_GS_Processor CPU on CPU.ResourceID = CS.ResourceID
right join v_GS_SYSTEM_ENCLOSURE SE on SE.ResourceID = CS.ResourceID
WHERE
LDisk.DriveType0 =3
GROUP BY
CS.Name0,
CS.domain0,
CS.Username0,
BIOS.SerialNumber0,
SE.SerialNumber0,
CS.Manufacturer0,
CS.Model0,
OS.Caption0,
RAA.SMS_Assigned_Sites0,
RAM.TotalPhysicalMemory0,
CPU.Name0
You'll have to have get report builder installed on your site server and just create a new report using the script above.
Machine Name
Make
Model
Kurt
What do you have for a query now? What is not working with it?
I don't have anything at the moment, this is very much my first use of creating a custom SCCM report.
I've installed report builder and created a new report. I've then attempted to add a new data set but unsure which source to select.
Apologies, very new to this.
SELECT distinct
FROM
WHERE
LDisk.DriveType0 =3
GROUP BY
CS.Name0,
CS.domain0,
CS.Username0,
BIOS.SerialNumber0,
SE.SerialNumber0,
CS.Manufacturer0,
CS.Model0,
OS.Caption0,
CPU.Name0
After a little playing around I managed to get the data source specified and ran your SCCM query. Can I ask would you know of a way to add the O/S version too so the report would display - Microsoft Windows 10 Enterprise and also the version such as 21H2 for example?
Thank you both for your help. I really appreciate your time
Sorry, I used the SQL script provided EdGonz. I've managed to get this working but I also need to have the O/S version such as 21H2. Would you know of an addition I can add to the SQL statement above to also retrieve this information?
Thank you for your help
To help point you within the right direction. Where exactly within ConfigMgr do you see that 21H2 listed within ConfigMgr console? This will point you towards the right sql view/colum to use to add to this query.
I've managed to get the information that I want but by using two separate reports.
This is a combination of the query above and then running the SCCM report Microsoft Windows Servicing details for a specific collection report. The included report has a field titled OS Release name which is the extra information I required.
I checked the report to see if there was an SQL query I could use as reference to update the SQL statement above but it seems to be written differently with the information coming from inside the report rather than an SQL query.
Would you be know of a way I can include OS Release name information in the SQL query above so that I don't need to run two separate reports?
Again, thank you so much for your help and any pointers. I really appreciate it.
That report use a function to get the OS release names. What you are asking for can be done but is not super simple. e.g. it would take more than a hour to create and test to ensure that everything is right.
You can try digging into the Official docs to see what else you can find. https://learn.microsoft.com/en-us/m...lviews/sql-server-views-configuration-manager
