NEW SCCM Client not working properly
CrisKolkman
Active Member
Hello all,
We have added a MP/DP/SUP in our DMZ (same domain as our prod domain) using this guide (for the firewall rules needed): https://docs.microsoft.com/en-us/ar...a-site-system-in-dmz-in-configuration-manager
The screenshot below shows a very simple diagram of our network but for the sake of the issue I don't think it's important to go into too much details here :)
Most of it is working fine only the MP itself is not reporting the client result (saying No Result) and when running the eval task I see below error in CcmEval.log:
Code:
Failed to get MDM_ConfigSetting instance, 0x80041013
The other clients in the DMZ don't have this error and they're reporting the client result to SCCM just fine.
The MP in the DMZ is the MP for all the clients in DMZ, including the MP itself (this MP is it's own MP).
Also: What I see on all the clients in the DMZ is that they seem to get all the client settings (policies) fine (confirmed this by checking the Defender exclusions etc) but one of the things (I found out so far) is that none of the clients in the DMZ apply the Client Cache settings which are defined for all the clients in the environment.
This value should be 60k and not adjustable.
Am I missing something here? I've checked a lot of logfiles on different clients in the DMZ but I don't see a lot of errors there.
SCCM version is 2111.
