I get some error when I try to install an sccm client from bat file.
When I start the installation ccmsetup.exe from network share it works without problem.
Do you have any idea?
Hello Prajwal, because we are deploying windows servers from VMware template and after that we run a script which one do some configuration(firewall, activation, SCCM Client install and so on)
Some month ago there was no problem with the script, after the client installation it always did a version upgrade without any problem. I think here is some problem because of Silverlight.
And when I start the client installation manually it works without any problem. Next time I will try the deployment with an older windows server template, maybe will help.
