Hey All,
Hopefully this is an easy one for you all, we have an SCCM environment setup and configured and working great for my primary domain. We have about 30+ domains to eventually be added, but working on the first one and its being a bit of a pain.
I'm not new to sccm and but very new for multidomain management and years separated from using sccm last.
I have extended schema, trust is in place, configured boundary groups (may be incorrectly?), by all accounts it appears that the agent is installed, but in portal it shows none for an agent.
Below is a server in the secondary domain and to the right(pending format stays the same) is the CM Console.
I do have a large boundary group configured to cover IPs.
Also have a domain admin service account for this domain added as a secondary choice in case first one doesn't take.
I am able to RDP to all these servers via name as well, so, believe DNS to be good.
I know this domain does have a WSUS gpo setup pointing to the WSUS server, should I disable that or can it be done after agent situation figured?
Any specific logs I should browse?
Sorry if these are dumb questions, just kind of at a loss here.
Thanks in advance.
Thanks in advance.
