SOLVED SCCM ADR for Endpoint Definition fails with error code 0x800701f7
  • Thread starter Thread starter Adel
  • Replies Replies 8
  • Views Views 8K
Adel
I have configured ADR for Endpoint definitions in sccm. It has been running for sometime until about three days ago it failed with error code 0x800701f7 and last error decription -2147024393. I have deleted and recreated but it doesn't get resolved.
ruleengine.log - some error msgs
STATMSG: ID=8706 SEV=E LEV=M SOURCE="SMS Server" COMP="SMS_RULE_ENGINE" SYS= SITE= PID=3196 TID=6932 GMTDATE=Sat Jul 18 22:42:11.299 2020 ISTR0="SMS Rule Engine" ISTR1="Failed to download one or more content files" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=0 SMS_RULE_ENGINE 7/18/2020 10:42:11 PM 6932 (0x1B14)
Rule XML is: <AutoDeploymentRule xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><DeploymentId>{2a6348e1-8fd2-46e6-8a68-a31fd305e6bb}</DeploymentId><DeploymentName>Endpoint Automatic Rule for Definition</DeploymentName><UpdateGroupId>ScopeId_E90FA3C4-CF27-4B28-A721-17E4EC67E656/AuthList_b42b2a6d-8778-48c1-adf4-2f0a477245f8</UpdateGroupId><UpdateGroupName/><LocaleId>1033</LocaleId><UseSameDeployment>true</UseSameDeployment><AlignWithSyncSchedule>true</AlignWithSyncSchedule><NoEULAUpdates>false</NoEULAUpdates><EnableAfterCreate>true</EnableAfterCreate><ScopeIDs><ScopeID>SMS00UNA</ScopeID></ScopeIDs><EnableFailureAlert>true</EnableFailureAlert></AutoDeploymentRule> SMS_RULE_ENGINE 7/18/2020 10:42:11 PM 6932 (0x1B14)
Criteria Filter Result XML is: <AutoDeploymentRule xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><DeploymentId>{2a6348e1-8fd2-46e6-8a68-a31fd305e6bb}</DeploymentId><DeploymentName>Endpoint Automatic Rule for Definition</DeploymentName><UpdateGroupId>ScopeId_E90FA3C4-CF27-4B28-A721-17E4EC67E656/AuthList_b42b2a6d-8778-48c1-adf4-2f0a477245f8</UpdateGroupId><UpdateGroupName/><LocaleId>1033</LocaleId><UseSameDeployment>true</UseSameDeployment><AlignWithSyncSchedule>true</AlignWithSyncSchedule><NoEULAUpdates>false</NoEULAUpdates><EnableAfterCreate>true</EnableAfterCreate><ScopeIDs><ScopeID>SMS00UNA</ScopeID></ScopeIDs><EnableFailureAlert>true</EnableFailureAlert></AutoDeploymentRule> SMS_RULE_ENGINE 7/18/2020 10:42:11 PM 6932 (0x1B14)
I need help to resolve this issue.
Thank u
Thank u
Hello Team, kindly assist me with this issue...waiting to hear from you soon.
If the ADR was working earlier then check the firewall and proxy settings. Check with your network team if there were any changes done recently. Do you have a proxy configured in your setup ?.
Thanks for the reply
I checked with our network team and there hasn't been any changes. Yes we do have proxy configured in our setup.
I think proxy is causing the issue for ADR. If you create again, same error will appear. I would suggest to go through below link Click me
No it wasn't available in the console.
Thank you so much for the support. It was indeed a proxy issue. The temporal solution that fixed the error was to configure the proxy server to by-pass windows updates from ICAP Scanning and the ADR error cleared after software updates synchronization, now endpoints are able to receive definition updates automatically.
Thank you once again for the support.
Sreeja
