SOLVED SCCM Admin console doesn't work,SCCM reset error and etc
Ali_Pashayev
Hi everyone,
Sccm stopped for several days.When i open admin console i get error.Firewalls are turned off on both servers(Sccm and SccmSql).
I also get an error when I do sccm reset to fix the problem.I've looked at almost all the forums, but it didn't work.
Thanks in advance for your support and valuable ideas.
When I open admin console error Event ID:
Transport error; failed to connect, message: 'The SMS Provider reported an error.'\r\nMicrosoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlQueryException\r\nThe SMS Provider reported an error.\r\n at Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlQueryResultsObject.<GetEnumerator>d__75.MoveNext()
at Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlConnectionManager.Connect(String configMgrServerPath)
at Microsoft.ConfigurationManagement.AdminConsole.SmsSiteConnectionNode.GetConnectionManagerInstance(String connectionManagerInstance)\r\nConfigMgr Error Object:
instance of __ExtendedStatus
Operation = "ExecQuery";
ParameterInfo = "SELECT * FROM SMS_Site WHERE SiteCode = 'BBB'";
ProviderName = "WinMgmt";
Error Code:
ProviderLoadFailure
\r\nSystem.Management.ManagementException\r\nProvider load failure \r\n at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
at System.Management.ManagementObjectCollection.ManagementObjectEnumerator.MoveNext()
at Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlQueryResultsObject.<GetEnumerator>d__75.MoveNext()\r\nManagementException details:
\r\n
Sccm Reset error:
*** Failed to connect to the SQL Server, connection type: servername.domain.com MASTER.
The ConfigMgr has lost connectivity to SQL server. Is the ConfigMgr database hosted on SQL server that exists on local machine or remote server?.
Thank you for your answer Prajwal.I solved the problem.A few days ago security update installed to dc1 and dc2.I uninstalled this updates.Working :)
