SOLVED SCCM 2012 R2 SQL updates
  • Thread starter Thread starter Biswajit
  • Replies Replies 9
  • Views Views 4K
Biswajit
Hi Pajwal,
As we stuck our SCCM installation and getting the below error.
Server: Windows Server 2008R2 SP1
SQL Server: SQL Server 2012 standard
Kindly suggest which update we need to install.
Hi prajwal,
I have only install SQL server 2012 standard, where I can get the cumulative update 2 or higher, plz share me the link for the success installation.
I Downloaded the CU2 from the given link & its successfully installed.:)
Thank you prajwal & Munassir, I am heading towards the configuration of Discovery & Boundaries. Hope Future support, if incase required.
Regards
Biswajit:)
Client push installation is not working for installing client in win7 machine, i followed all given step by step installation. did i have to copy client installation file anywhere in win7 or it will pick automatically. its not showing in task manager process.
Regards
Biswajit
