NEW SCCM 2012 DP. Which folder and process exclusions will be required as a prerequisites?
Vignesh1010
I want to add new distribution point in sccm 2012 environment. We are using mcafee agent.
Grateful if you could respond the query at earliest.
Thanks for your response.
Could you please confirm for Distribution point server. Below list is enough?
Folder exclusions for site systems:
  • Distribution Points
    • Client Installation Folder\ServiceData
    • ContentLib_Drive\SMS_DP$
    • ContentLib_Drive\SMSPKGDrive_Letter$
    • ContentLib_Drive \SMSPKG
    • ContentLib_Drive \SMSPKGSIG
    • ContentLib_Drive \SMSSIG$
Folder exclusions for clients
  • Client Installation Folder\*.sdf
  • C:\Windows\CCMCache
  • C:\Windows\CCMSetup
  • Client Installation Folder\Logs
Process exclusions
Process Exclusions are necessary only if aggressive antivirus programs consider System Center Configuration Manager executables (.exe) to be high-risk processes.
  • ConfigMgr Installation Folder\bin\x64\Smsexec.exe
  • Either of the following:
    • Client Installation Folder\Ccmexec.exe
    • MP Installation Folder\Ccmexec.exe
  • Client Installation Folder\CmRcService.exe (client-side)
  • ConfigMgr Installation Folder\bin\x64\Sitecomp.exe
  • ConfigMgr Installation Folder\bin\x64\Smswriter.exe
  • ConfigMgr Installation Folder\bin\x64\Smssqlbkup.exe, or SMS_SQLFQDN\bin\x64\Smssqlbkup.exe
  • ConfigMgr Installation Folder\bin\x64\Cmupdate.exe
  • Client Installation Folder\Ccmrepair.exe (client-side)
  • %windir%\CCMSetup\Ccmsetup.exe (client-side)
Marda
