LucaSilc
Hello! So i would like to know if someone else have this problem.
Description: You deploy Windows 10 on a PC. Install goes fine, everything should work as it should, but you cannot access PC via remote control viewer. On the installed PC everything seems to work fine. The Site Code is assigned, certificate installed etc. Remote Connection Enabled...
So, I try to push install the client again, uninstall the old agent, reinstall, and still no luck.
Anyone else had this problem? What might cause this behaviour? Any solution?
Thank you!
Thank you!
