OPEN Running script in user context
  • Thread starter Thread starter VodKen
  • Views Views 11K
VodKen
Hello everyone,
I'm looking for a way to run scripts not via the system user but rather for the logged in user. The background is that I want to read out the user's certificates which are about to expire. Is there a possibility here?
Hello everyone,
If it is a powershell script, you could actually input the username and password with parameter in your SCCM script, and the make the script declare a credential object with those parameters and do a PSSession to the machine itself with these credentials and voila, you are able to execute your powershell script inside that "wrapper"
Use this as an example.
Code:
Param(
    [Parameter(Mandatory=$True, Position = 0)]
    [String]$Username,
    [Parameter(Mandatory=$True, Position = 1)]
    [String]$Password
$CredentialPassword = ConvertTo-SecureString $Password -AsPlainText -Force
$Credential = New-Object System.Management.Automation.PSCredential ($Username, $CredentialPassword)
$ComputerName = ([System.Net.Dns]::GetHostByName($env:computerName)).HostName
$CommandResult = Invoke-Command -ComputerName $ComputerName -ScriptBlock {
    $ObjectProperties = @{
        Username = $env:USERNAME
        UserDomain = $env:USERDOMAIN
    $Result = New-Object -TypeName psobject -Property $ObjectProperties
    return $Result
} -Credential $Credential
return $CommandResult
Hello everyone,
This is a loaded question? Can you run a script in user mode? For sure, use Packages running in user context.
Can you run scripts using CM console? No.
Kahnrym
