PetrH
Hi guys.
I have one problem here, in newly deployed task sequences my execution does not work. The installation "hangs" for about an hour when it ends with the code 0x0 (0), the required task sequences are not installed at all. In the "Monitoring" section of the console, I see that this is "in progress", but no details. I'm adding a screenshot from the inplace upgrade log plus TSAgent.log. The content is now at about eight distribution points, I don't think it should be caused by that. Thank you for any advice, I will add more info on request.
