PENDING Problems with InPlace Upgrade in SCCM 2012 1606 CU
Buzzie
Hello all,
In the beginning when i started using SCCM 2012 i managed to do an OSD from Windows 7 just fine.
What i wanted to do as well was do an inplace upgrade from Windows 7 to Windows 10.
That didnt work so well so i tried several other possibilities but with no luck.
I havent looked at it for a while and now i want it to work.
What i did was make task sequences ofcourse for the inplace upgrade.
But what i just noticed was that when i have the possiblity to do in upgrade from within Windows 7, it finds for some reason old task sequences.
I had 3 of them in my SCCM but i disabled 2 of them and even deleted them except 1 coz that is the one i made this week.
How can i get rid of them and make sure that the right task sequence is running for the inplace upgrade??
Prajwal do you happen to have any idea about this problem?
is there a way to empty the cache of some sorts?
you could delete all the TS and create only one TS and deploy ?. Of course you can back up the TS settings before you delete.
snokas
