PENDING Problems installing Configuration Manager Client
  • Thread starter Thread starter mike88
  • Replies Replies 7
  • Views Views 4K
mike88
Hi everyone.
I am making crazy. I have problems installing the agent of Configuration Manager on the computers.
On DC and the only SCCM server I have no problem to install the client.
I have tried a lot of solutions:
- Firewall disabled at computer and SCCM Server.
- My account is local administrator account.
- I have connection to \\computer\admin$ with the account.
- Checked with WBEMTEST i have connection to the computer and to the server.
This is the ccm.log from the server:
======>Begin Processing request: "2097152005", machine name: "MITECO3" | SMS_CLIENT_CONFIG_MANAGER Execute query exec [sp_IsMPAvailable] N'MIT' | SMS_CLIENT_CONFIG_MANAGER | 22/02/20---> Trying each entry in the SMS Client Remote Installation account list | SMS_CLIENT_CONFIG_MANAGE---> Attempting to connect to administrative share '\\MITECO3.test.local\admin$' using account 'TEST---> SspiEncodeStringsAsAuthIdentity succeeded! | SMS_CLIENT_CONFIG_MANAGER | 22/02/20---> SspiExcludePackage succeeded! | SMS_CLIENT_CONFIG_MANAGER | 22/02/20---> SspiMarshalAuthIdentity succeeded! | SMS_CLIENT_CONFIG_MANAGER | 22/02/20---> NetUseAdd succeeded! | SMS_CLIENT_CONFIG_MANAGER | 22/02/20---> Connected to administrative share on machine MITECO3.test.local using account 'TEST\admin_sccm---> Trying the 'best-shot' account which worked for previous CCRs (index = 0xFFFF) | SMS_CLIENT_CON---> Attempting to make IPC connection to share <\\MITECO3.test.local\IPC$> with Kerberos authentica---> SspiEncodeStringsAsAuthIdentity succeeded for IPC$ authentication! | SMS_CLIENT_CONFIG_MANAGER ---> SspiExcludePackage succeeded for IPC$ authentication! | SMS_CLIENT_CONFIG_MANAGER | 22---> SspiMarshalAuthIdentity succeeded for IPC$ authentication! | SMS_CLIENT_CONFIG_MANAGER | ---> NetUseAdd succeeded for IPC$ authentication! | SMS_CLIENT_CONFIG_MANAGER | 22/02/20---> Searching for SMSClientInstall.* under '\\MITECO3.test.local\admin$\' | SMS_CLIENT_CONFIG_MANAG---> Unable to connect to remote machine "MITECO3.test.local" using Kerberos with alternate account--> NTLM fallback is enabled, remote machine "MITECO3.test.local" is continuing with client push. | ---> System OS version string "10.0.19044" converted to 10,00 | SMS_CLIENT_CONFIG_MANAGER | ---> Unable to connect to WMI (root\ccm) on remote machine "MITECO3.test.local", error = 0x8004100e---> Creating \ VerifyingCopying existence of destination directory \\MITECO3.test.local\admin$\ccm---> Copying client files to \\MITECO3.test.local\admin$\ccmsetup. | SMS_CLIENT_CONFIG_MANAGER ---> Copying file "C:\Program Files\Microsoft Configuration Manager\bin\I386\MobileClient.tcf" to "M---> Copying file "C:\Program Files\Microsoft Configuration Manager\bin\I386\ccmsetup.exe" to "ccmse---> Updated service "ccmsetup" on machine "MITECO3.test.local". | SMS_CLIENT_CONFIG_MANAGER | ---> Deleting SMS Client Install Lock File '\\MITECO3.test.local\admin$\SMSClientInstall.MIT' | SMS_Execute query exec [sp_CP_SetLastErrorCode] 2097152005, 0 | SMS_CLIENT_CONFIG_MANAGER | 22/---> Completed request "2097152005", machine name "MITECO3". | SMS_CLIENT_CONFIG_MANAGER | Deleted request "2097152005", machine name "MITECO3" | SMS_CLIENT_CONFIG_MANAGER | 22/02/20Execute query exec [sp_CP_SetPushRequestMachineStatus] 2097152005, 4 | SMS_CLIENT_CONFIG_MANAGER Execute query exec [sp_CP_SetLatest] 2097152005, N'02/22/2022 12:22:39', 20 | SMS_CLIENT_CONFIG_MANA<======End request: "2097152005", machine name: "MITECO3". | SMS_CLIENT_CONFIG_MANAGER | 22
The main errors are:
---> The 'best-shot' account has now succeeded 2 times and failed 0 times. SMS_CLIENT_CONFIG_MANAGER 22/02/2022 13:25:13 9788 (0x263C)
---> Unable to connect to remote machine "MITECO3.test.local" using Kerberos with alternate account, error - 0x800706ba. SMS_CLIENT_CONFIG_MANAGER 22/02/2022 13:25:13 9788 (0x263C)
---> Unable to connect to WMI (root\ccm) on remote machine "MITECO3.test.local", error = 0x8004100e. SMS_CLIENT_CONFIG_MANAGER 22/02/2022 13:25:14 9788 (0x263C)
Execute query exec [sp_CP_SetLastErrorCode] 2097152005, 0 SMS_CLIENT_CONFIG_MANAGER 22/02/2022 13:25:16 9788 (0x263C)
Please help me, I have checked a lot os thing.
That log snip-it is find, it show the client is installed. Why do you say it is not?
The client in Configuration Manager doesn´t appear with the client installed and in the Control Panel neither
Did you read the client side logs? That will give you more details but from the client push log, it was successful.
Hi @Garth.
Is possible the computers needs connection to internet to install the client?
Cause I have provided connection to Internet to the computer and the client is installed now.
Hi @Garth.
There should be no need for it to have an Internet connection.
Hi.
Here attach the log, from the server and from the client "MITECO1"
One proccess fails and the second it´s ok after I added an external network adapter in my Hyper-V lab with Internet connection.
Before the client just have Private network adapter with communication between Domain Controller and Configuration Manager/SQL server.
lynnc
