NEW Problems deploying packages running PowerShell scripts
DavidBrookesPTA
Have an issue when deploying packages running PowerShell scripts on a couple of different machines. Packages are failing to install via the SCCM client but will when run manually from the downloaded source from SCCM in PowerShell ISE. I am getting the following errors:
App enforcement environment:
Context: Machine
Command line: C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe -ExecutionPolicy Bypass -NoProfile -file .\CardaxCommandCentreInstall.ps1
Allow user interaction: No
UI mode: 1
User token: null
Session Id: 2
Content path: C:\WINDOWS\ccmcache\1o
Working directory: AppEnforce 14/12/2022 2:37:09 PM 2728 (0x0AA8)
Prepared working directory: C:\WINDOWS\ccmcache\1o AppEnforce 14/12/2022 2:37:09 PM 2728 (0x0AA8)
Prepared command line: "C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe" -ExecutionPolicy Bypass -NoProfile -file .\CardaxCommandCentreInstall.ps1 AppEnforce 14/12/2022 2:37:09 PM 2728 (0x0AA8)
Executing Command line: "C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe" -ExecutionPolicy Bypass -NoProfile -file .\CardaxCommandCentreInstall.ps1 with user context AppEnforce 14/12/2022 2:37:09 PM 2728 (0x0AA8)
Working directory C:\WINDOWS\ccmcache\1o AppEnforce 14/12/2022 2:37:09 PM 2728 (0x0AA8)
ScriptHandler::EnforceApp failed (0x80070005). AppEnforce 14/12/2022 2:37:09 PM 2728 (0x0AA8)
AppProvider::EnforceApp - Failed to invoke EnforceApp on Application handler(0x80070005). AppEnforce 14/12/2022 2:37:09 PM 2728 (0x0AA8)
CommenceEnforcement failed with error 0x80070005. AppEnforce 14/12/2022 2:37:09 PM 2728 (0x0AA8)
Method CommenceEnforcement failed with error code 80070005 AppEnforce 14/12/2022 2:37:09 PM 2728 (0x0AA8)
++++++ Failed to enforce app. Error 0x80070005. ++++++ AppEnforce 14/12/2022 2:37:09 PM 2728 (0x0AA8)
Issue has occurred with more than one package using a PowerShell script to deploy the package. Can anyone please help?
DaveDave
