PENDING Problem With Upgrade offline 1702 to 1706 cb
nir
Hi we work no internet connection (offline mode ), so to upgrade Sccm 1702 to SCCM 1706, i had to download the 27GB files required for the prereq. So i did that and started the update..
It failed everytime on a file hash check - and failed on different files.
I downloaded them and copied them over 3 times, also logged in as a different admin user and tried but got the same error, so basically it's stuffed
anyone encountered the same problem and what they did to resolve it
this is short log with error :
INFO: Adding Permission: IF OBJECT_ID('EN_SetEnrollmentError') IS NOT NULL GRANT EXECUTE ON [EN_SetEnrollmentError] TO [smsdbrole_EnrollSvr] 09/10/2017 10:16:19 AM 3364 (0x0D24)
ERROR: Failed to get the buffer size for LookupAccountName. Error = 1332 09/10/2017 10:16:20 AM 3364 (0x0D24)
WARNING : The content has been changed without increase the Version. 09/10/2017 10:17:00 AM 3364 (0x0D24)
INFO: Removing byte order marker after reading from file (F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\AndroidDeepLinkInstallerTechnology.xml) 09/10/2017 10:17:03 AM 3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\00000409\ADSite.resx)(0X80070714) 09/10/2017 10:18:34 AM 3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\f:\program files\microsoft configuration manager\bin\x64\00000409\adsite.resx)(0X80070714) 09/10/2017 10:18:34 AM 3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\00000409\CPUSpeed.resx)(0X80070714) 09/10/2017 10:18:34 AM 3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\f:\program files\microsoft configuration manager\bin\x64\00000409\cpuspeed.resx)(0X80070714) 09/10/2017 10:18:34 AM 3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\00000409\Device_FreePhoneMemory.resx)(0X80070714) 09/10/2017 10:18:34 AM 3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\f:\program files\microsoft configuration manager\bin\x64\00000409\device_freephonememory.resx)(0X80070714) 09/10/2017 10:18:34 AM 3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\00000409\Device_MinOSVersion.resx)(0X80070714) 09/10/2017 10:18:34 AM 3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\f:\program files\microsoft configuration manager\bin\x64\00000409\device_minosversion.resx)(0X80070714) 09/10/2017 10:18:34 AM 3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\00000409\Device_MinAPILevel.resx)(0X80070714) 09/10/2017 10:18:34 AM 3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\f:\program files\microsoft configuration manager\bin\x64\00000409\device_minapilevel.resx)(0X80070714) 09/10/2017 10:18:34 AM 3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\00000409\Device_OwnershipDesktop.resx)(0X80070714) 09/10/2017 10:18:34 AM 3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\f:\program files\microsoft configuration manager\bin\x64\00000409\device_ownershipdesktop.resx)(0X80070714) 09/10/2017 10:18:34 AM 3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\00000409\Device_OwnershipMobile.resx)(0X80070714) 09/10/2017 10:18:34 AM 3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\f:\program files\microsoft configuration manager\bin\x64\00000409\device_ownershipmobile.resx)(0X80070714) 09/10/2017 10:18:34 AM 3364 (0x0D24)
And more 30 files
WARNING: File hash mismatch for F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\Client\x64\msrdcoob_amd64.exe 09/10/2017 10:18:35 AM 3364 (0x0D24)
WARNING: File hash mismatch for F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\Client\x64\wic_x64_enu.exe 09/10/2017 10:18:54 AM 3364 (0x0D24)
ERROR: File hash check failed: 0x80070002 09/10/2017 10:18:54 AM 3364 (0x0D24)
ERROR: VerifyExternalFile failed: 0x80070002 09/10/2017 10:18:54 AM 3364 (0x0D24)
ERROR: Failed to find valid source for required external file 09/10/2017 10:18:54 AM 3364 (0x0D24)
ERROR: Failed to find valid source for required file 'wic_x64_enu.exe'. Aborting setup. 09/10/2017 10:18:54 AM 3364 (0x0D24)
Setup has encountered fatal errors while performing file operations. 09/10/2017 10:18:54 AM 3364 (0x0D24)
Failed to install update files. 09/10/2017 10:18:54 AM 3364 (0x0D24)
Failed to apply update changes 0x80004005 09/10/2017 10:19:04 AM 3364 (0x0D24)
escdarck
