NEW Problem with displaying updates in sccm
  • Thread starter Thread starter Zigmax
  • Replies Replies 1
Zigmax
Hello, friends
My problem is the following, I hope you can guide me about it
In the SCCM console, in the software updates / all software updates section, when viewing in the column of required and installed computers, they appear as 0 for versions that are managed, for example I have 2 versions of windows 10, versions 1803 and 1809, but only version 1809 is displayed (normal), but in version 1803 they appear at 0 and it is not modified, even synchronizing with wsus, this error happens to me this month (March), the previous month (February) it was updated without any problem , I know that it is still something easy, but I cannot find the solution in this regard since all the components are displayed and everything is in perfect working order.
I attach an image of the problem itself, and I hope it helps you understand a bit of the problem, as it happens with several versions of windows
Before hand thanks for the help
Regards!!
The actual applicability of an update and what a system installs is not determined by what the console shows. So try to deploy the same to test devices. Initiate the scan and check wuahndler.log
