PENDING Problem using DellWarranty-CLI.exe
  • Thread starter Thread starter MdKnightR
MdKnightR
I've been attempting to follow these instructions for using the DellWarranty-CLI, but the command DellWarranty-CLI.exe setup_config produces the following message:
Error: An invalid command line option (setup_config) was supplied
Has anyone else had this issue?
Revisiting this,
Under the 6.2 tool you need to provide one of two [Required] parameters. Either /InputFile or /InputCfgMgrConnectionString parameter.
An example of what this would look like (using a server name of: SERVER.COM and a site DB name: CM_AAA) would be:
DellWarranty-CLI.exe /Ics="Data Source=SERVER.COM;Database=CM_AAA;Integrated Security=true;"
The documentation can be found at https://dl.dell.com/content/manual5...n-6-2-user-s-guide.pdf?language=en-us&ps=true
