NEW Problem SMS_WSUS_SYNC_MANAGER
  • Thread starter Thread starter Immort4l
  • Replies Replies 1
Immort4l
Good morning, I am new to your society. Before I start, I apologize for my English.I manage the SCCM console environment at my employer and I have version 2111 installed. Recently we had a problem with SUP because it did not synchronize patches for windows. I found out that one of the employees logged on to sup and accepted the patches from the console windows server update services manually using the console. After unsuccessful attempts to repair I decided to reinstall SUP on a new virtual machine. Product patches are already synchronizing correctly and we are able to control and update rollups and security. Product patches are already synchronizing correctly and we are able to control and update rollups and security. However, there was another problem with the feature updates for windows 21H2 for older versions are visible. As I force synchronizations appears to me error in the log wsyncmgr.log I will try to post it below. Mention that WCM.log is fine.
Good morning,
Subject to be closed. The solution is to run cmd.exe as a user with full SQL database administrator. Go to "C:\ Program Files\Update Services\Tools" respectively and run the "WsusUtil.exe reset" command. The command checks the metadata in the SUSDB database and the corresponding WSUSContent files. If it finds damaged or missing, the tool downloads it again and accepts the EULA.
Regards
Immort4l
