NEW Problem on DP reassignation
  • Thread starter Thread starter Kranebus
  • Replies Replies 0
Kranebus
I'm working on the migration of a sccm primary site to a new hardware.
Both SCCM are in 1906.
Here the actions I've done :
1) Setup up source hierarchy
2) I migrated all objects (collection, package, etc.)
3) I enabled distribution-point sharing for the source site
4) I reassigned a DP which was eligible for reassignement
Some packages on this DP are still pending
I have done these actions on the DP :
1) Reinstallation of the configuration manager client from the destination SCCM and now the site code is good
2) I modify the expiration date of the certificate to update it
But when I run the smsdpmon.exe the content validation doesn't work. I have error messages in the smsdpmon.log :
1) After the line Getting algorithm ID --> Failed to find algorithm ID from registry. Use default algorithm.
2) After the line Getting this DP NALPath I have these 3 lines :
Failed to create certificate store from encoded certificate. Verify the provided Certificate was provisioned correctly. .
Unknown error (Error: 80092002; Source: Unknown)
Failed to initialize DP monitoring object. Error code: 0x80092002
Do you have any ideas ?
Is there any good practice to do the job I want to do ?
Thanks for help
Regards
SteveL
