PENDING Problem: How can I configure SCCM 2012 to use a shared folder location for patches and fixes?
  • Thread starter Thread starter SCCM002
  • Replies Replies 5
SCCM002
How can I configure SCCM 2012 to use a shared folder location on the trusted network for patches and fixes? Is it possible? Thanks in advance.
There is no internet connection on our network. There is only a shared folder which consists of windows updates files on trusted network. I would like to find out that whether sccm can be configured only to use that shared folder to get downloaded packages from there. Thanks in advance.
Yes you can do that.
There is no real trick to this, as you deploy each SU you need to point it to that folder and it will continue from there.
I mean SU will be seen and reachable in All Software Updates in SCMM? If it is like that, I need configuration procedures for that?
TOMMhah
