PENDING Problem deploying Server 2016 since updating to ConfigMgr 2303
David Mynatt
I am currently unable to deploying Server 2016. This worked before I updated ConfigMgr from 2207 to 2303. It is failing to install the ConfigMgr client. We are able to deploy Server 2019 and 2022 with no issues.
This is what I have found in the smsts.log:
Executing command line: C:\_SMSTaskSequence\OSD\SBH00001\ccmsetup.exe /useronly /source:C:\_SMSTaskSequence\OSD\SBH00001 /config:MobileClient.TCF /status:736 with options (0, 0) OSDSetupHook 12/27/2023 2:41:42 PM 2384 (0x0950)
Process completed with exit code 6 OSDSetupHook 12/27/2023 2:42:00 PM 2384 (0x0950)
Client installation failed, code 6 OSDSetupHook 12/27/2023 2:42:00 PM 2384 (0x0950)
Non fatal error 0x80070057 in sending task sequence execution status message to Management Point OSDSetupHook 12/27/2023 2:42:00 PM 2384 (0x0950)
Executing command line: "C:\WINDOWS\system32\_SMSOSDSetup\TsProgressUI.exe" /Unregister with options (0, 0) OSDSetupHook 12/27/2023 2:42:02 PM 2384 (0x0950)
==========[ TsProgressUI started in process 2356 ]========== TsProgressUI 12/27/2023 2:42:02 PM 2912 (0x0B60)
Unregistering COM classes TsProgressUI 12/27/2023 2:42:02 PM 2912 (0x0B60)
Shutdown complete. TsProgressUI 12/27/2023 2:42:02 PM 2912 (0x0B60)
Process completed with exit code 0 OSDSetupHook 12/27/2023 2:42:02 PM 2384 (0x0950)
Successfully unregistered Task Sequence Progress UI. OSDSetupHook 12/27/2023 2:42:02 PM 2384 (0x0950)
Failed to install SMS Client (0x80004005) OSDSetupHook 12/27/2023 2:42:02 PM 2384 (0x0950)
Does anyone know what the problem is?
