PENDING Powershell Script Deploy
  • Thread starter Thread starter harveybham
  • Replies Replies 5
harveybham
Hi All,
I have a Powershell script that we have created that we need to push to all machines.
The script needs to look at a .csv file (Same patch as the script) and it needs to pull the hostname and another field.
Inside the same folder is a uninstall tool which also needs to run.
Doing this manually it works. So I run the script , it looks up the uninstall, it looks up the csv and it works.
What is the best way to push this via SCCM? Iv tested using a package and it says installed but it has not removed the program.
The command line i used is Command line: Powershell.exe -ExecutionPolicy ByPass -File "ScriptName"
Hi @harveybham,
You can deploy the Powershell script as an application or package then you can monitor the deployment status and keep the deployment for active/inactive devices.
Thanks for the reply
iv tested running this as a package but it seems to quick and moves to installed.
If i was to do this as a application how could i do the detection method. This script is only removing the application
You can add a detection method of a file or register key, for example if the C:\Program Files\Google\chrome.exe is not present, the script is compliant.
Hi All,
Thanks for the replies. I got this working in the end and had to use a Task Sequence for this to work. There was an issue with the script which also got fixed but this can now be marked as resolved. Thanks for the feedback
