PENDING PowerBI SSRS Datasource connection issues
  • Thread starter Thread starter Pivax88
  • Views Views 462
Pivax88
I recently installed PowerBI Reporting Services which went fine. The issue I am having is the account authentication for the datasource for some reason keeps failing to authenticate. If I then re-enter the password, apply it and test the connection, it works again, I can view maybe 1 report, but then the next report fails with the following error:
When I check the datasource again and test the connection, it fails due to incorrect password. If I change the authentication method to anything else, it works for a single report or time period, then fails and reverts back to the settings it had before with the incorrect password!
lynnc
