A AAhmed New Member Messages 3 Reaction score 0 Points 1 Feb 5, 2020 #1 We've already deployed Power BI 2.70.xx via SCCM. I need help in deploying the latest version of Power BI 2.76.xx via SCCM.
Youssef Saad Well-Known Member Staff member Messages 676 Solutions 10 Reaction score 80 Points 28 Feb 6, 2020 #2 Hi Ahmed, Have you tried first to install it directly to check if the new replace automatically the old version ? Upvote 0 Downvote
OP A AAhmed New Member Messages 3 Reaction score 0 Points 1 Feb 6, 2020 Thread Starter #3 Hello Youssef, You mean deploy a new package with the existing app package left as is? Regards, Anwaar. Upvote 0 Downvote
Youssef Saad Well-Known Member Staff member Messages 676 Solutions 10 Reaction score 80 Points 28 Feb 6, 2020 #4 Disable the deployment from the old version. Install the new package. You can try this locally first with executing the same package its command installation line. Upvote 0 Downvote
Leon.Theorn New Member Messages 3 Reaction score 0 Points 1 Mar 3, 2020 #5 MS announced the retirement of the MSI installer from 1st Sep 2019. That leaves only the EXE to be used I have found that the following syntax works for me PBIDesktopSetup_x64.exe -silent -norestart -update ACCEPT_EULA=1 And Uninstall PBIDesktopSetup_x64.exe -silent -uninstall I then use the Registry as Detection Method Hope this helps L. Upvote 0 Downvote
OP A AAhmed New Member Messages 3 Reaction score 0 Points 1 Mar 9, 2020 Thread Starter #6 Thank you Leon. Did you deploy this as a package or script? Thanks, Anwaar. Upvote 0 Downvote
Leon.Theorn New Member Messages 3 Reaction score 0 Points 1 Mar 10, 2020 #7 I create a package with that string as the install string You can get the uninstall and detection method from the registry L Upvote 0 Downvote
