PENDING Post SOE issue
  • Thread starter Thread starter heeramoni
  • Replies Replies 7
heeramoni
Hi, we are facing post SOE build computer issue. SCCM can’t discover some assets.
What we have checked:
  • Ccmsetup.log – showing “return code 0”
  • Checked boundaries which is okay
  • Checked Site under “Configuration Manager Properties” and it can “Find Site”
  • Under “Configuration Manager Properties” it is showing Client certificate: None. I have manually installed PKI but no luck
  • Under action it is showing only two actions: “Machine Policy Retrieval” and “User Policy & Evaluation..”
  • A month ago it was working perfectly.
  • C:\Windows\Ccm\Logs\Smsts.log “Successfully finalized logs to SMS client log directory from C:\WINDOWS\CCM\Logs”
  • Question, after successfully build is completed, any asset is not visible in the system center. Can anyone advice please?
Are you using ONLY IP Rangers for boundaries? What do the site server logs say? Have you refreshed the collection membership?
Thanks Garth for your reply.
Yes, only IP rangers for boundaries.
Which logs you are referring to?
I have just refresh the collection membership.
If the client is installed, I would review the log files to ensure the communication with management point is working.
