PENDING Package stuck installing
piggywhiskers
Version 2309
I've deployed a package that will run a PS script. The script works fine when run through PowerShell on the client, software installs, but when running it via Software Centre it gets stuck installing.
Deployed from Distribution Point.
Looking at exec.mgr log, I have this last line of action and then nothing more:
MTC task with id {73776C76-F5F5-47EB-B40C-CC17305ED230}, changed state from 4 to 5
Any suggestions?
Command line = "C:\WINDOWS\system32\WindowsPowerShell\v1.0\powershell.exe" -executionPolicy unrestricted -noexit -file "Agent 3.0.1 Package.ps1"
Version 2309
Any suggestions?
I don't see any issues with that command. Try what @rob287 mentioned.
just had a quick look at one of mine that deploys a BIOS package via Ps.
C:\WINDOWS\system32\WindowsPowerShell\v1.0\powershell.exe -Bypass -Command "&{.\****.ps1}"
Thank you, this progressed it further!
Rob287 did help, I am past the MTC issue. That being siad not gettting:
Code:
MTC task with id {64B8CD21-C6A5-482F-A302-0E5E36020A89}, changed state from 4 to 5    execmgr    26/01/2024 10:21:45    4396 (0x112C)
Program exit code 1    execmgr    26/01/2024 10:21:46    4412 (0x113C)
Looking for MIF file to get program status    execmgr    26/01/2024 10:21:46    4412 (0x113C)
Script for Package:FRC00BE7, Program: NCPA Agent failed with exit code 1    execmgr    26/01/2024 10:21:46    4412 (0x113C)
Raising event:
[SMS_CodePage(850), SMS_LocaleID(2057)]
instance of SoftDistProgramErrorEvent
    AdvertisementId = "FRC2271F";
    ClientID = "GUID:32C22773-B9F1-4236-ABA1-0C5C279EA7E8";
    DateTime = "20240126102146.587000+000";
    ExitCode = "1";
    MachineName = "SGEN-WG02";
    PackageName = "FRC00BE7";
    ProcessID = 5712;
    ProgramName = "NCPA Agent";
    SiteCode = "XXX";
    ThreadID = 4412;
    UserContext = "NT AUTHORITY\\SYSTEM";
Raised Program Error Event for Ad:FRC2271F, Package:FRC00BE7, Program: NCPA Agent    execmgr    26/01/2024 10:21:46    4412 (0x113C)
Execution is complete for program NCPA Agent. The exit code is 1, the execution status is FailureNonRetry    execmgr    26/01/2024 10:21:46    4412 (0x113C)
This machine is not a workstation, returning false for MDMIsExternallyManaged.    execmgr    26/01/2024 10:21:46    4412 (0x113C)
So migtht be something to do with the script, but it does work when running it normally.
Bit further now, changed the suggestiong from: C:\WINDOWS\system32\WindowsPowerShell\v1.0\powershell.exe -Bypass -Command "&{.\****.ps1}"
to
C:\WINDOWS\system32\WindowsPowerShell\v1.0\powershell.exe -ExecutionPolicy Bypass -Command "&{.\****.ps1}"
It runs, no errors, but doesn't install at all. o_O
I guess the script is fine, but from the log, i see this:
to
Just needed the executionpolicy in there. Glad i could help
jordysmits
