SOLVED Package model command line modify
arun ganesh
Hi
I'm creating package model to deploy an application. I have create a program(command line) and distributed to DP's and made the s/w available. Now suppose I modify the existing command line do I need to redistribute or will the changes will replicate automatically?
Yes, whenever you modify the command line or package properties, you need to redistribute the package to all DP's.
@ Prajwal
Do we need to re-distribute it in case of "Application Model" or your statement is true and limited to "Package Model"
Kindly confirm. Thanks
Thanks for your quick response mate. I am looking for a way to deploy CMTRACE tool to all our PCs.
Any suggestion/pointers to blog post for this purpose?
Nairolf
