Raghuasr29
- Solutions
- 1
So this is weird issue I got here and I know the fix as well but just don't know how to implement it.
I PXE boot the machine or a VM and it goes to TS selection window. I select the required TS and click next, and boom it fails. Failed to Run Task Sequence - An Error has occured while starting the task sequence (0x8007000f)
Solution -
After this solution, if it ask for a reboot and TS works fine. Same issue on VMs and Physical Computer.
This is my TaskSequence for this
Nothing seems to work here, can anyone advise how can I fix this issue?
Solution -
