PENDING OSD Error Exiting with return code 0x80070005
Robert Hill
Hello, I want to thank you ahead of time for taking a look at this error
When I try and deploy an image to a computer, PXE boot is working I get a correct IP address, but then the computer just reboots. I have the SMSTS.log file. Not sure what this error means.
LOGGING: Finalize process ID set to 844 TSBootShell 18/11/2017 07:28:14 848 (0x0350)
==============================[ TSBootShell.exe ]============================== TSBootShell 18/11/2017 07:28:14 848 (0x0350)
Succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL' TSBootShell 18/11/2017 07:28:14 848 (0x0350)
Debug shell is enabled TSBootShell 18/11/2017 07:28:14 848 (0x0350)
Waiting for PNP initialization... TSBootShell 18/11/2017 07:28:14 892 (0x037C)
RAM Disk Boot Path: NET(0)\SMSIMAGES\STC00005\BOOT.STC00005.WIM TSBootShell 18/11/2017 07:28:15 892 (0x037C)
Booted from network (PXE) TSBootShell 18/11/2017 07:28:15 892 (0x037C)
Network(PXE) path: X:\sms\data\ TSBootShell 18/11/2017 07:28:15 892 (0x037C)
Found config path X:\sms\data\ TSBootShell 18/11/2017 07:28:15 892 (0x037C)
Booting from removable media, not restoring bootloaders on hard drive TSBootShell 18/11/2017 07:28:15 892 (0x037C)
X:\sms\data\WinPE does not exist. TSBootShell 18/11/2017 07:28:15 892 (0x037C)
X:\_SmsTsWinPE\WinPE does not exist. TSBootShell 18/11/2017 07:28:15 892 (0x037C)
Executing command line: wpeinit.exe -winpe TSBootShell 18/11/2017 07:28:16 892 (0x037C)
The command completed successfully. TSBootShell 18/11/2017 07:28:18 892 (0x037C)
Setting offline Windows drive and OS root directory to TS envirtonment. TSBootShell 18/11/2017 07:28:18 892 (0x037C)
Processing volume A:\ TSBootShell 18/11/2017 07:28:18 892 (0x037C)
Volume A:\ is not a local hard drive. TSBootShell 18/11/2017 07:28:18 892 (0x037C)
Processing volume D:\ TSBootShell 18/11/2017 07:28:18 892 (0x037C)
Volume D:\ is not a local hard drive. TSBootShell 18/11/2017 07:28:18 892 (0x037C)
Processing volume X:\ TSBootShell 18/11/2017 07:28:18 892 (0x037C)
Volume X:\ is not a local hard drive. TSBootShell 18/11/2017 07:28:18 892 (0x037C)
_OSDDetectedWinDrive='', _OSDDetectedWinDir='' TSBootShell 18/11/2017 07:28:18 892 (0x037C)
Starting DNS client service. TSBootShell 18/11/2017 07:28:18 892 (0x037C)
Executing command line: X:\WINDOWS\system32\cmd.exe /k TSBootShell 18/11/2017 07:28:19 848 (0x0350)
The command completed successfully. TSBootShell 18/11/2017 07:28:19 848 (0x0350)
Successfully launched command shell. TSBootShell 18/11/2017 07:28:19 848 (0x0350)
Executing command line: X:\sms\bin\x64\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\ TSBootShell 18/11/2017 07:28:19 892 (0x037C)
The command completed successfully. TSBootShell 18/11/2017 07:28:19 892 (0x037C)
==============================[ TSMBootStrap.exe ]============================== TSMBootstrap 18/11/2017 07:28:19 1080 (0x0438)
Command line: X:\sms\bin\x64\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\ TSMBootstrap 18/11/2017 07:28:19 1080 (0x0438)
Succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL' TSMBootstrap 18/11/2017 07:28:19 1080 (0x0438)
Succeeded loading resource DLL 'X:\sms\bin\x64\TSRESNLC.DLL' TSMBootstrap 18/11/2017 07:28:19 1080 (0x0438)
Current OS version is 10.0.16299.0 TSMBootstrap 18/11/2017 07:28:20 1080 (0x0438)
Adding SMS bin folder "X:\sms\bin\x64" to the system environment PATH TSMBootstrap 18/11/2017 07:28:20 1080 (0x0438)
PXE Boot with Root = X:\ TSMBootstrap 18/11/2017 07:28:20 1080 (0x0438)
Executing from PXE in WinPE TSMBootstrap 18/11/2017 07:28:20 1080 (0x0438)
Loading TsPxe.dll from X:\sms\bin\x64\TsPxe.dll TSMBootstrap 18/11/2017 07:28:20 1080 (0x0438)
TsPxe.dll loaded TSPxe 18/11/2017 07:28:20 1080 (0x0438)
Device has PXE booted TSPxe 18/11/2017 07:28:20 1080 (0x0438)
Variable Path: \SMSTemp\2017.11.18.07.22.33.0011.{B6A83630-E4FF-453A-806E-244045E5E21A}.boot.var TSPxe 18/11/2017 07:28:20 1080 (0x0438)
shService.null() == false, HRESULT=80070005 (e:\nts_sccm_release\sms\server\pxe\tspxe\fwopen.cpp,40) TSPxe 18/11/2017 07:28:20 1080 (0x0438)
PxeStartFirewallService(), HRESULT=80070005 (e:\nts_sccm_release\sms\server\pxe\tspxe\fwopen.cpp,92) TSPxe 18/11/2017 07:28:20 1080 (0x0438)
PxeCreateFwTftpRule(sTftpExe.c_str()), HRESULT=80070005 (e:\nts_sccm_release\sms\server\pxe\tspxe\tspxe.cpp,165) TSPxe 18/11/2017 07:28:20 1080 (0x0438)
PxeGetPxeData failed with 0x80070005 TSPxe 18/11/2017 07:28:20 1080 (0x0438)
HRESULT_FROM_WIN32(dwError), HRESULT=80070005 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmbootstraputil.cpp,1518) TSPxe 18/11/2017 07:28:20 1080 (0x0438)
TSMBootstrapUtil::PxeGetPxeData(&bPxeBooted, sVariablesFile, sPxePasswd), HRESULT=80070005 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,2692) TSPxe 18/11/2017 07:28:20 1080 (0x0438)
oTSMediaWizardControl.Run( sMediaRoot, true, sTSLaunchMode ), HRESULT=80070005 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmbootstrap.cpp,1110) TSPxe 18/11/2017 07:28:20 1080 (0x0438)
Execute( eExecutionEnv, sConfigPath, sTSXMLFile, uBootCount, &uExitCode ), HRESULT=80070005 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmbootstrap.cpp,1258) TSPxe 18/11/2017 07:28:20 1080 (0x0438)
Exiting with return code 0x80070005 TSPxe 18/11/2017 07:28:20 1080 (0x0438)
hMap != 0, HRESULT=80070002 (e:\cm1702_rtm\sms\framework\tscore\environmentscope.cpp,493) TSPxe 18/11/2017 07:28:20 1080 (0x0438)
m_pGlobalScope->open(), HRESULT=80070002 (e:\cm1702_rtm\sms\framework\tscore\environmentlib.cpp,335) TSPxe 18/11/2017 07:28:20 1080 (0x0438)
this->open(), HRESULT=80070002 (e:\cm1702_rtm\sms\framework\tscore\environmentlib.cpp,561) TSPxe 18/11/2017 07:28:20 1080 (0x0438)
Execution complete. TSBootShell 18/11/2017 07:28:20 892 (0x037C)
hMap != 0, HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentscope.cpp,493) TSBootShell 18/11/2017 07:28:20 892 (0x037C)
m_pGlobalScope->open(), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentlib.cpp,335) TSBootShell 18/11/2017 07:28:20 892 (0x037C)
this->open(), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\environmentlib.cpp,561) TSBootShell 18/11/2017 07:28:20 892 (0x037C)
::RegOpenKeyExW (HKEY_LOCAL_MACHINE, sKey.c_str(), 0, KEY_READ, &hSubKey), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\utils.cpp,831) TSBootShell 18/11/2017 07:28:20 892 (0x037C)
RegOpenKeyExW is unsuccessful for Software\Microsoft\SMS\Task Sequence TSBootShell 18/11/2017 07:28:20 892 (0x037C)
GetTsRegValue() is unsuccessful. 0x80070002. TSBootShell 18/11/2017 07:28:20 892 (0x037C)
End program: TSBootShell 18/11/2017 07:28:20 892 (0x037C)
Finalizing logging from process 844 TSBootShell 18/11/2017 07:28:20 892 (0x037C)
Finalizing logs to root of first available drive TSBootShell 18/11/2017 07:28:20 892 (0x037C)
LOGGING: Setting log directory to "X:\SMSTSLog". TSBootShell 18/11/2017 07:28:20 892 (0x037C)
TSMBootstrapUtil::pxeGetPxeData(&bPxeBooted, sVariablesFile, sPxePasswd), HRESULT=80070005 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,2692) TSPxe 18/11/2017 07:28:20 1080 (0x0438)
Hi Everyone..
This is my first post on this forum. Hope everyone is keeping safe.
I have the exact same error while trying to deploy a Windows 10 hyper-v on my test lab. I've been pulling my hair out for the last 3 days and can't seem to get a solid answer to this error.
I'm running Windows 2016, SCCM 2012 R2 with CU4. ADK 1903 and WinPE latest. I have a DP with PXE and WDS.
I have tried different flavours of Windows, different boot disks and TS. Re-enabled DP for PXE. Everything!
I can't get past the network stage, however, I do get a valid IP.
Any pointers would be appreciated.
Thank you
Aymendakout
