NEW OSD Build and Capture Fails - The operating system reported error 617
pauljebastin
Configuration Manager Build and Capture (Workgroup Joined) fails during Application Installation steps with following error. Any suggestions please what i am missing here. Thanks
The task sequence execution engine failed execution of a task sequence. The operating system reported error 617: You have attempted to change your password to one that you have used in the past. The policy of your user account does not allow this. Please select a password that you have not previously used.
try a restart step after "setup windows and configuration manager".
I added a restart step after "Setup Windows and Configuration Manager" but it gives me an another error when the run after restart option is "The boot image assigned to this task sequence" during Install Application Step as follows:
The task sequence execution engine failed executing the action (Install Applications) in the group (Build the Reference Machine) with the error code 50
Action output: . The operating system reported error 50: The request is not supported.
Then when I changed Restart step with "The currently installed default operating system", application started again failing with The operating system reported error 617.
Did a silly mistake, resolved after adding configuration manager client installation properties. All good now.
dimasyandr
